Kelly Holdridge said:
Heya! Dig your studio shots, would like to know more about the chicken wire/foil thing (EVERYbody does!).
I was hoping you'd share what you know about magnetic shielding, and particularly whether this foil thing will work for the same purpose. We've got a thread going in the Cave, guess this was a better place for it. Also, please check out the thread in Visitor Feedback on a possible physics/tooling forum. You sound like the guy to head it up if it's a viable idea.
Thanks, good luck with your studio!
Thanks for the great feedback! So you wanna know more about magnetic shielding do ya?
I'll try condensing it down to the easiest way to understand as possible.
Everyone knows, or a lot of people at least, that when you pass a magnet by the leads of a volt meter, you'll see the voltage jump up for a second. The reason it does that is because the leads are cutting the magnetic lines of flux, and for a short time there is a small amount of current. You've seen those tests where someone poors metal shavings on a peice of paper resting on a magnet havn't you? And the shavings form lines all around the magnet. When you pass something metal through one of those lines it induces a voltage. Now, take that theory and try to understand the next part... When you broadcast a signal from a radio station, or TV station, what you're sending out is none other than magnetic lines of flux. The antenna on your radio or TV cuts the magnetic lines of flux, much like the leads of the voltmeter, and it runs the current through an amplifier and you get music. Understand that? Now, say you were to put metal all around your stereo, would it do anything to your reseption? Not unless you give that small amount of current some place to go. Where would you put a small amount of current? The earth loves to accept current. Another name for this is "Grounding". And since the amount of current is SO small, there's not a chance in hell you're going to fry anything. So, if you've got your radio inside a metal box that is hooked to ground, the metal box is going to CUT ALL THE MAGNETIC LINES OF FLUX before they get to the radio and send them to ground.
I hope this cleared a little bit of confusion up, and maybe someone actually learned something
haha.
Have you ever been in a metal building and just couldn't get your radio to come in? Oh man, I have. I worked in a metal building for 2 years and couldn't get crap on the radio. Just 2 days ago I moved to a wooden building just 15 feet away and I get all the stations.
Later,
-Brian
[Edited by Brian Grey on 09-20-2000 at 05:50]
