suprstar
It aint ez being green
I am starting up a new band that will be practicing in my basement. I need to soundproof as well as possible, my budget is around $1k. Soundproofing is my #1 goal, unlike most of the other posts I'm finding. I'll deal with room acoustics eventually, but I need quiet first - our first rehearsal is in 3 weeks. We'll be kinda quiet anyway, the drummer will be using my v-drums, so we'll all be able to turn WAAAYY down to begin with.
The room is appx 20'x15', and the bottom of the ceiling joists are exactly 8'. The ceiling joists are appx 1 foot deep (11 7/8 I-joists), so I can pack a lot of fiberglass batting, closed cell foam, rockwool, etc. The plan is to pack whatever in between the joists, and hang drywall to the ceiling. I may also add a layer of green glue and a 2nd layer of drywall if time/$ permit. The drywall is no prob, I'm wondering about the filler.
For the joist cavities, has anyone tried this closed cell foam?
http://www.bestchoiceinsulation.com/_mgxroot/page_10812.html
It claims to absorb sound VERY well, and costs about $1 per cu. ft installed. A few hundred bucks for the whole ceiling.
Otherwise I'll probably just stuff as much fiberglass batting in there as possible. I am also considering a 2" layer of Roxul AFB mineral wool, and stuffing the remainder of the space with fiberglass batts. Pricier, but if it works better I can swing it.
OC703/705 is out of my price range, and I beleive 12" of batting or cc foam will provide better sound absorption than 2" of ANYTHING, even OC705. Is that true, or is the OC stuff really that good? Not to mention I can get all the batting I want locally in minutes...
I'm hesitant to try resilient channel, because they say most ppl screw up the install, then it has little to no effect.. Costs too much for me to risk it so... I know it won't be perfect, hopefully it'll be enough.
My last concern (currently) is this: One of the 15' sides opens up to the rest of the basement, about a 30'x30' square room with the stairs in the middle. I'm not going to be treating those ceilings right away because they're under different rooms where I don't care how loud it is up there. But if it's loud in the kitchen or dining room, that sound will bleed into the family room, hopefully at sufficiently low levels.
Any additional tips, thoughts, ideas, etc before I start buying materials? Thanks,
