cordura21
Bass Drum hole, question for Harvey
Harvey, I was reading your article called "Some Common Misconceptions About Music" and you say that although the hole in the front head can be used to "port" the drum like a bass reflex speaker to have a better bottom end, this is unnecessary as the front head itself acts like a passive radiator, thus resonating the air inside the drum.
My question is: doesn't the presence of that hole change or cancels the resonation that the front head gives to the drum? And shouldn't you try to keep the hole as small as you can, maybe even plugging the mic inside the drum and then closing it? Or is it too much, as the sound of a bigger hole is much the same of a smaller?
Cheers, Andrés
Cheers, Andrés
