O
OldGrover
Ok, so let me see if I understand. I run pink noise to the amp and adjust it until I get the right voltage coming out of the amp. I then join the speaker to the amp using the a light bulb, trying different light bulbs until I get one that starts to glow orangish after 1-2 seconds.
Ok, three questions. 1. Does that mean that the light should not be lit at all originally or during normal use? So in normal use it is pretty dark and only orangish when it is getting hit hard? 2. What happens if, then, I take my faders and whack 'em up to the top. 250 Watts at 8 ohms goes screaming down the wire and what? The lightbulb gets bright but my speakers survive? Is that it? That'd be cool. 3. Where do I get a pink noise generator? Is there a standalone computer proggie that'll work?
And just to re-remind myself, I wire the light bulb into the BLACK wire, right?
So, the completed setup would be :
black wire from amp ----- light bulb ----- speaker
white wire from ap ------------------------- speaker
Sound right?
Is there any guidance on what size of bulbs to use, say with 70 watt 6 ohm speakers? (YSM-1s) How do you calculate what voltage you are supposed to get for a 70 watt, 6 ohm?
I guess that is 5 questions, but thanks very much for the help!
(btw, Tragically Hip "New Orleans is Sinking" Live at New Orleans bootleg ROCKS. God, that is a great example of just playing and rocking out in front of an audience)
Sound right?
