JordanDoyle
I have a very convoluted audio setup to run my microphone through some post-processing stuff but live, I initially used Virtual Audio Cable but the latency had to be above 50ms in Audition otherwise the audio would become extremely choppy. I instead decided to use WASAPI which works perfect at 10ms latency, but I couldn't run that through Virtual Audio Cable due to it having to go through the microphone, so I got out my old mixer and decided to run the headphone jack (which Audition liked to output to) to the mixer, it worked perfectly and then I ran the output to the mixer to the Line In port of my PC, however, when I opened Audition there was a very audible buzz which only seemed to happen when Audition got the "handle" to the Blue Yeti, if I switched the device, the buzz went away.
I can hear the buzz through the mixer before it even goes into the Line In port of the PC, I've tried changing the wire but nothing seems to work. What can I do to fix this problem?
Recording with Audacity from the Line In port: https://www.mediafire.com/?apcj1tapsxfrecp
Thanks,
Jordan.
Thanks,
Jordan.
