lpdeluxe
The Precision Bass Guy
Part III
There's something else that bugged me about 2.0, in contrast to the earlier versions: it seems like I can easily cut and paste, mix and paste, delete and so on without it affecting the length of the files. When I do the same with 2.0, I end up with a track out of synch because it's now shorter or longer. I'm willing to believe there's something I'm overlooking, but -- with the other things I don't like about 2.0 -- I've never gone back and tried to find out what.
My recordings incorporate live performances with overdubs, or pieces from other recordings inserted into whatever I'm working on. As noted previously I don't do sequencers or loops or other "cheaters" (no offense, everyone I record has a stage band background, and wouldn't know a synth if it ran up to them on stage and wagged its tail).
Tuesday I pieced together a 96-minute lecture with audience questions and edited it down to 76 minutes, so it'd fit on a CD for distribution to persons who had missed the event. The speaker had a wireless directional mic clipped to his shirt, and was recorded into a computer on the premises loaded with CEP 2.0. I set up an additional condenser mic facing the audience, but the configuration of the original wireless setup didn't allow me to record that to CEP simultaneously; I plugged it into a Korg D888 and recorded that track independently of the first. As a consequence, not only were the two tracks not synchronized, they were different overall lengths since the two machines had been started and stopped at slightly different times.
I copied the lecture onto a thumb drive and took it and the Korg home, where I imported both into a single session of AA 1.5.
The first chore was to move the lecture track to Edit View so I could edit out enough time to meet the CD max time limit, so I went through the whole hour and 36 minutes and [ctrl/C] cut out verbal stumbles, false starts, coughs etc until I had a natural sounding track under the 80 minute time limit. Of course, I also did noise reduction and compression as needed.
The audience track then got the noise reduction and compression treatment. I then found the places where the speaker paused to listen to questions, found that particular question on the second track, did a "Bounce to empty track" for that segment and then slid it into place (hard to do perfectly, so I did a crossfade for each instance of inserting the questions).
When I was done, I had a listenable CD with intelligible questions and clarity in all elements.
It was time consuming but next week will be easier (the guy who set up the single-channel wireless will be back from Panama, and we'll have both tracks going into the Korg).
My point? This was all so easy -- if time-consuming -- in the earlier version of Audition. My experience trying similar chores in 2.0 has been frustrating and has usually ended in failure.
