C
Codeseven
Hi guys.
Sorry, I've done a Search, theres' a ton of posts on this topic, but I still find it confusing
Anyhow, I'm recording guitar and vocals into Garageband. I have 4 main devices I'm using. A 2008 MacBook Pro, TC Helicon Voicelive Play GTX, Presonsus Firepod and Fender Mustang amp. My signal path is.....Guitar-> MBP via Rocksmith USB, Voice Mic->TC Helicon via XLR, TC Helicon-> MBP via USB, MBP->Firepod via firewire 400, Firepod-> Amp via 1/8" stereo cable into AUX.
There are a couple caveats to why everything is connected this way. On my laptop the headphone jack is old and loose so due to poor connection I cannot use it for audio in or out. I could connect both the Guitar and Voice Mic to the TC Helicon and run two XLR cables from it to the Firepod (in Dual Mono) but I thought it better to have only a one way path on the firewire from the MBP rather than two way to and from it. Also, on the TC Helicon, I'm using it's USB to the laptop because I can't use it's headphone out to my laptops crappy headphone jack. I want to establish the fewest connections and shortest signal path to avoid latency issues of course.
That does leave me with using different modes of signal transport with different capablilities to think about, 1/8" stereo cable, USB, XLR and Firewire 400.
I see in Audio Devices on my laptop that I can choose which device is the master clock but that's the point at which I need help from you guys.
Also.....there's the issue of Hz/bit rates. Shouldn't all devices be set at the same Hz/bit rate, if possible? My Firepod is capable of 96Hz/24 bit, TC Helicon is 24 bit, ? Hz, I believe my MBP is capable of 96Hz/24bit but the Rocksmith USB is only 44Hz/16bit.
Thanks
Thanks
