Aspect ratio
I
ibanezac
I'm a professional photographer for 20 years, and the last year I started filming. It was by accident, I filmed a music video, and I liked it. Since then I filmed several videos and all of them are in 16:9. But I noticed different aspect ratios on YT, so the question Is it normal to have black stripes over and under like here:
or is it a must to be clear:
It depends on what your target format is. TVs today are generally 16:9 (1.78:1). Some computer monitors are extra wide at around 2.37:1 for gaming. Phone screens are generally 2.16:1 (Iphone 17, 18, Galaxy 25, etc).
If you are doing 2.39:1 - Anamorphic Scope film to get a very wide shot, you'll have black bars on top and bottom of a 16:9 TV screen. Many SciFi films like Dune and The Dark Knight are done this way. It's more "cinematic" in appearance. It should also fill an UltraWide monitor.
If you go with 1.85:1 - Flat Widescreen which is most US based films, it's not much different from the 16:9 format which is 1.78:1.
Netflix and AppleTV have adopted a 2:1 ratio which looks ok on a normal TV and pretty much fills the screen on things like a cell phone in landscape mode. You might have small bars on the top and bottom but they are minimal.
For a while there were lots of DVDs in two formats, widescreen and letterbox. A film in 4:3 format would have bars on the sides of a widescreen. Widescreen versions would have bars on the top and bottom of a 4:3 TV screen. With the widespread adoptions of widescreen flat panel TVs, Letterboxing went away except for things like old TV series.
Thank you for the answer. But is it normal to have black stripes, or is it a must to be clear?
Yes, it's normal. If you film for ultrawidescreen and play it on a normal flatscreen, there are going to be bars. If you film in 4:3 and play it on an ultrawidescreen monitor, you either have bars on the sides or the people are twice as wide as they should be.
It's no difference than taking video on your cell phone in vertical mode and playing it back on a normal monitor. That's an extreme case, playing a video that is vertically set at 1:2 on a horizontal screen that is 1.7:1. If you play the video on a phone vertically, you see the picture without bars. It's simple arithmetic based on pixel ratio V and H. In photograph it's portrait vs landscape.
If you don't have the bars, the image would look like this!
Which would you prefer?
On most TV stations, they will blur the image and place those copies on the sides because people don't like the black bars. If you simply turn your phone on the side when recording, it will look fine on a TV, but small if you hold the phone vertically.
I would suggest you consider using 2:1 which has been dubbed Univisium. It's close to a phone screen, decent on a regular widescreen computer monitor or 16:9 TV. If you are mostly targeting TV, then just go 16:9.
The alternative is the TV zooming in and chopping a bit of picture off.
That's usually ok if you're watching a film.
