cjacek
Analogue Enthusiast
I agree. What's the point of vinyl if it's from a digital source, other than it looking cool.
my purism is about capturing an authentic sound. Not fancy or contrived, flashy or "commercial", (heaven forbid).
For that, may I suggest The Device:It's about the output being as close as possible to the input, ...![]()
However, for the cost of prosumer microphone preamps, equalizers, & especially compressors, you can make your own DIY versions, many of which are of classic designs which you will pay thousands for. I’ve just finished a Stereo Neve Mic Pre clone, Stereo SSL Mixbus compressor, & am working on a 1176 compressor & Stereo Tube Opto Compressor similar to a LA2-A.
I’ve come to the conclusion that everyone needs at least some outboard gear with audio transformers on board for that larger than life sound & a tube guitar amplifier of course. You can also get away with cheaper mics with better outboard, I’ve really been surprised with dynamic mics used with the Neve Mic pre clone I built, even a T-Bone Ribbon cheapo priced at £50 sounds great, I never even liked a Audio Technica SM58 type mic I’ve had for 20 years until it went through this pre.
That's Only if you choose to do so....classic designs which you will pay thousands for...
OK As requested
SSL 4000 Mix bus Compressor Clone with added Super Sidechain Board c/w API Thrust Filter (Don't know what that does exactly but sounds great) & various high pass settings. Great on the main outputs of your mixer & drum buss. Needs one more control knob for the set so I've used another type for now!
I'm actually going to make another different (Turbo) version of one of these with my own case! Was a fiddly build especially as it's my first, had to redo a main PCB board along the way being a newbie! Case was built by Perusha on the Prodigy DIY Forum.
Neve 1290 Stereo Mic Pre, build in progress working & almost finished. Have just tested my first channel with excellent results, waiting for a couple more transformers & parts for Channel 2 . I'm just adding a DI / Phase / Pad interface board now. Just got to drill the front panel & print out transfers for the settings & writting for the controls.
I'll post more when I'm finished
Nice! Where are you getting the parts and schematics?
Various projects over on http://www.prodigy-pro.com/diy/index.php?board=2.0
All project & details on the META thread above, PCB's available http://www.prodigy-pro.com/diy/index.php?board=3.0
Advice , troubleshooting & how to build links are all on Prodigy DIY forum
because somebody must've voted...
