M
Morningloryseed
Hello all
Here is my background...
I record onto the old Yamaha 8 Track mini-disk recorder. It's has decent sound. I have a nice collection of tools to help me capture the sound including six channels of wonderful ART tube pre-amps (two channels which have built in limiters and dials to tailor the sound according to the job), a couple channels of DBX 266 XL compressor, an AT 4033 condenser mike (beautiful microphone), a couple of SM 57s, and a few other things for effects and equalization.
My biggest influence as far as recording is definitely George Martin/The Beatles. My recording style tends to use a lot of tube warmth (everything I record goes through the tubes), very little compression except when needed, and not too many effects unless the application really calls for it. For things like effects/modulations on the guitar, keyboard, or base I like to add them before I record the sound.
At mix down I may add a little reverb to many of the instruments if it calls for it to “make it sound whole”, and I tend to add some delay to vocals. I mix down to a stand alone CD burner. The signal goes from the 8 track into the ART tube preamp (each channel of the stereo picture goes through a different tube channel obviously), and into my compressor. I usually bypass the compressor unless one of two particular peaks is causing problems. Instead, I try to compress as I record. If I don't bypass it, I use the compressor very sparingly. From the compressor, the signal is recorded onto the CD burner. I record as loud as possible to lower any noise from the tubes and the amplifier in the burner. But the amount of noise produced is negligible.
I then take the songs from the mix down CD and load them into Cool-edit pro 2.0. I wonder if it would be better to skip the burner and record from the 8 track directly into the computer hard drive. But they are different rooms and it's nice to have a CD back-up of my mix down. I just don't trust hard-drives.
I then tidy up the tracks with Cool-edit pro (fade outs, maybe some final equalization, etc) and burn the final master to CD with Nero.
What I wonder is...
The normalization issue has me confused. I've read perhaps four threads in this forum on normalization and there are so many contradictions. Many say never normalize. I do limit everything to -1 or -.5 with Cool-edit pro so I see the point of there being no reason for further normalization since it is already as loud as it can be.
Anyone want to take their time to add/comment/advise? I sure would appreciate it. I hope I'm not rehashing already-discussed topics, but I haven't seen any threads that relate to my specific situation. Thanks so much.
MGS
What I wonder is...
- *Should I limit and normalize with Cool-edit pro?
*Should I limit with Cool-edit pro and then use Nero to normalize before the burn?
* Or just limit with Cool-edit pro and then burn with Nero using no normalization?
MGS
