Tadpui
Thanks guys, so cranking the gain more and rolling back the tone on the bass have helped the most. For some reason I had it backwards and thought cranking the gain would distort things so I was cranking the output more. What I found is cranking the output gives a cleaner/brighter and more "flabby" sound, to my ears at least. Cranking the gain gives a slightly dirty, rounder sound, especially with the tone down like 50%. It's less "flabby" but still sounds a little flabby, but the tone is much better. By flabby it's almost like the note falls apart instead of remains tight. I wonder if this is strings or the pickups...I know the MIM don't have the best pickups, but not sure if it's worth sinking $70 into upgrading them when the sound is like 90% where I want it.
I think that you're on the right track, and that's a pretty stellar preamp. Since it's patterned after the gold standard Neve 1073, it should be able to give you nice fat low end and a smooth and detailed high end. And like you've discovered, giving it some input gain will help fatten it up. You might try turning up the input gain until it just starts to distort on the louder notes, then dial it back a bit from there. Then adjust the output so it gives you the desired signal strength on your interface/DAW.
I've been lusting after a BAE 1073 for a while now. I found a used one at a great price, but it's still in a different league of expense. That's a lot of money for a guy like me, just some schlub in his basement. But I waaaaant one
![Smilie :) :)](/images/smilies/smile.gif)
