Okay...okay...uncle!
You guys...
That was like a team-tag...I respect you both...yer playing, like, good-cop bad-cop...
Msh focuses on the subject of the mics and Ethan drops the hammer.
Just for clarification, I was looking into it because I've seen some other "797 Audio" mic mods secondary to poor design that were simple and very beneficial, and I'd had issues using either of these mics on a recent project where they sounded harsh and brittle, but this (pulling them apart and polling for opinons) was kind of the final straw to putting the question to bed as to whether or not the issues were mic related or something else in the signal path. I think it may have been a cable issue or something else. Tracked again last week with an SM57 and SM94 array through the M-520 and the sound was very smooth even after ADC on playback monitoring the DAW. Granted I'm not using the C1 or B3, but the harshness/brittleness was present to some degree with
any mic before this last session...its gone now, and to top it off I did some tracking of my 3 1/2 year-old son's latest creation last night, vocal and acoustic guitar. Signal path:
- B3 x2 in a simple X-Y array at relatively close proximity to source, polar patterns set to cardioid, no low cut or pad -->
- Tascam MX-80 (phantom power supplied by a Stewart Audio single channel supply into the MX-80 phantom rail) -->
- MX-80 SEND jacks to Tascam 424mkII LINE inputs 1 & 3 direct to tracks 1 & 3
Wow...tracked at 3 3/4ips with dbx on, and just monitoring off tape with Sennheiser HD280 cans I...could...not...believe...the presence and detail.
So, yeah. I'm going to leave them alone...your comments nailed the lid. Thanks.
Ethan, sorry to bust your balloon here...you're right. I
do need to focus, but I'm hot on the M-520 mod warpath right now...just 4 channel's worth, but recapping is becoming a relatively easy task now, and caps are cheap...I need to pull cards to clean contacts, and if I'm gonna pull the cards I may as well recap and swap out some opamps...you may have read in another post but the M-520's behavior on that recent tracking session was nearly embarrassing...not the mixer's fault but when you have to dicker with source-select and assign switches every few minutes because you keep hearing excessive noise and/or losing signal completely, its time.
I want to try and have at least two of the 4 done (or hopefully all 4) by the next session which is on the 18th.
Then my attention is going to turn to the 48-OB, which is looking promising as far as actually having that ready to run amidst the current project...Then it may be time to do more M-520 channels, then the
BR-20T,
then the 58...the M-___ will certainly keeping popping in and out because its just too interesting...nearly ready to put the frame and motherboard assembly back together on that one...
