A
affleckp
I hope you can take a few min to help clarify this for me. I am new to recording and am trying my best to learn. I am recording into a digi002r/ada8000 using Protools in my DAW. I have the snare, BD, sm tom, Med Tom, Fl tom, lt overhead, rt overhead miced. I have recorded the drums separately from the guitars bass and vocal tracks which were recorded through a GT Brick pre. All my compression\eq\effects are done in the DAW. When recording the drums should I shoot for as high a peak as possible to 0db or should I look for -3 to -6db peak? What should the peak relationship be from each level? When I recorded the Bass drum and snare peaked close to -1 but the other levels were closer to -4 or -5db. Should I try to match peaks for each level? Even though you normally want the Bass drum and snare louder? The reason I ask is after final bounce the mix is not as loud as I would like. The master level is not clipping and I am peaking at about -1db and the level seems to stay at -3 to -2 almost all the time. Would lower initial peaks for the Bass drum\snare been better? Would that have allowed me more room to increase the final mix level? I know I can compress\limit the hell out of the track to get higher levels but I'm just wondering if my initial recording is hampering the final mix. If you get a chance and have nothing better to do please listen to http://www.myspace.com/downfromnothing the final song Breathe. Please don't be too hard on me this is only my 4th or 5th try at this! Thanks in advance for any help!!
