R
RAMI
Guest
You're compounding problems while trying to fix them.(the singer is in a corner).........we've been having trouble maintaining clarity and volume on the vocals while battling feedback. the foam seems to have helped a good bit, actually.
Vocals in the corner is a horrible idea. That's where you have the most bass build-up in a room. This is the reason you're "having trouble maintaining clarity and volume." The bassiest part of the room is being recorded, which will affect clarity a lot. Now, you added foam, which might have taken away your feedback problem, but also took away the little bit of high-end you had by singing in the corner. So, now you have an even bassier and less clear sound.
Seems like you're looking for any excuse to not do it properly and you're just replacing one problem with another. I undestand that money is an issue, and I can relate, as I'm sure most of us can. But you can still do things that will help you work with what you got. One of them is learning a bit about acoustics so that you can help yourself. For example, without spending a penny, if you move the singer out of the corner, you'd probably end up getting a clearer and nicer sound because A)He's not in the corner, and B) You won't need to use the foam that's making the recording even less clear.
