BeatsBuY
Here's some tips I've made over the years... Enjoy...
Tips how to mix and master like a pro.
By: Aaron Reppert
Mixing and mastering is an art in itself. It takes time to find your own techniques and how to become a pro mixer. These tips will help you get your projects done faster and give you a professional result.
Make a session template
In your audio software program, make a session template. This is a session with all the tracks, plugins and settings already setup. This is what you will use when recording a new project.
Mix as you record
When in the pre production and recording stage, you want to EQ and mix as you record. This will save you time during the mixing stage. Before recording, get a microphone test with the artist. Compress and EQ the vocal with the plugins in the session. When you get the settings perfect, just copy and paste each plugin setting to the next recorded track. Do the same for each new recorded artist. Don't forget to label each track in the session as well.
On the master fader, put an EQ and maximizer plugin. (There are many maximizer plugins. So find the one that works best for you in your audio program.) This will give you an idea how the mastered track will sound. With out the maximizer plugin, levels will be softer and less impacting for you to reference. Vocals and instruments will not be as up front as it would going through a maximizer plugin. This will give you an idea on how to mix the session before it goes to mastering. These steps are very important because you don't want your track to change drastically during mastering.
Make custom settings
Another great tip is to make individual plugin settings for each artist you record. This way when you record, you just bring up that artist plugin setting and you are ready to go. Remember that every artist has a different style and vocal tone, so you need to make a custom plugin setting.
Do's and Don'ts
Don't get into the mode and say, "Oh, I'll just fix it in mastering." Always, fix any problems with the mix in the "mixing stage". Mixing gives you more options then mastering. When you mix and master your tracks, you may go back and forth in the mixing and mastering stages. Say that you are in the mastering stage and just realized that the bass is too load. Instead of lowering the bass EQ mix in mastering, go back to the mix and lower the bass track in the session. Then go back to master it. That's why you have the maximizer plugin on the master fader in mixing so you don't have to go back and forth.
Different reference speakers
One of the things to remember is that mixing on studio speakers don't really give you a reference how it will sound on a boom box or car speakers. Buy a cheap boom box with an aux input and hook it up to you system. You will switch between the studio speakers and boom box during the mixing and mastering stage. This will tell you if you have to much bass and if the levels are mixed right. On the boom box, switch the different user settings.
1. Classic
2. Rock
3. POP
4. Vocal (and so on)
You want your mix to sound good in all these user settings, not just one. I would recommend setting up a car stereo receiver and car speakers to get the feel of how your mix will sound in a car. You can buy a car stereo power converter at your local Radio Shack to hook up the car receiver in your studio.
Also, play your mixes on your computer speakers. Make sure your mixes sound perfect on the computer speakers as well.
Sound Proof the studio
One important issue that people over look is sound proofing. If you have an untreated room, you may find that you are not getting the accurate references to you mixes. Ever mix your song and play it in your car and find you had to much or to little bass? This is because your room may accent the bass or absorb to much bass in the room. You need to treat the room with acoustic foam.
Auralex is the premiere company when it comes to studio room treatment. Treating the entire room can get expensive so just treat the main problem areas in the room. This means corners, reflections, and the walls.
1. Use bass traps to fix problem corners that may reflect and build up bass. This is a very important treatment to make.
2. Get rid of any items in the studio that may cause sound reflections. This means mirrors, metal objects, and flat walls.
2. Carpet treat the floor. This will save you money on treating the ceiling with foam.
3. Add studio absorption wall foam to certain parts of the wall. >photo
With these tips you should be on your way to making great masters.
By: Aaron Reppert
Mix as you record
Do's and Don'ts
1. Classic
2. Rock
3. POP
