Nola
Say I want to record bass guitar and compress a little so the notes are more even. I don't have a compression pedal or a hardware compressor, so if i use a vst on the bass' track, does that compress the signal in the same way an outboard compressor or a pedal would?
Also, say I record the bass without compression and then add compression later. Does that have the same effect as if recording with compression on in the first place?
Thanks.
Thanks.
