M
mixsit
There are areas in the frequency range where bass and kick need to meld, but for the most part, they will add to each others boomy or ringy sound in the low end.
You have to play it on a case by case basis. 'All the way down (-18 whatever..) hardly ever that much.When you say cutting out certain frequencies, do you drop very specific areas almost all the way down or do you just lower them a little? And just how specific areas are we talking about?
But some times you have to consider that a kick can be decaying too long, or the bass might be sustaing the notes more than is wanted. Either or both of those can pile up as time/envelope shape problems that get in the way of a nice tight defined low end you might be trying to sort out. -that's on top of pure frequency balance eq issues.
I just tackled one tonight where (not the first time) after eq'ing nine different ways ended up adding an expander to the bass guitar track to get it to poke through and not desolve into the mix.
In part a time rather than just tone' solution.
