Amp to PC through stereo? HELP!
  • Thread starter Thread starter aufan03
A
aufan03
I have a Behringer Ultraacoustic acx 1000 amp which has two stereo outputs (RCA Jacks) in the back. So, if I were to get a card with stereo inputs installed in my pc, could i record straight from my amp? Here is the amp: http://www.behringer.com/ACX1000/index.cfm?lang=ENG So, what do I need in order to go from the amp to a soundcard? Thanks in advance.
Newbie :s
yes, that would work, but you will get a much better sound if you just mic the amp. If it acoustic, get some condensor mics, and if it is distorted, grab a shure sm-57 mic. Also make sure you either get a small yamaha mixer or a preamp for your mics. You can run the amp directly into something like the audiophile 2496 by m-audio, but you will need a software program, like n-tracks, available at www.fasoft.com .
Guess someone posted while i was typing....lol, another program you could look at beside n-trak is Home Studio by Cakewalk http://www.cakewalk.com/ not very expensive..... not 45 dollars either as is n-trak..... but it is a great program....
Good Luck
Chris
If I were to just run out of my amp into my sound card...
would I run the risk of damaging anything?
As long as you don't run from your speaker out or headphone out to your soundcard, you should be fine (technically, you could probably get away with using a headphone out, and it would sound like crap for the most part). With your line outs into your sound card you should be fine (it won't be the most quality stuff, but it won't break anything either). However, if your sound card does not have RCA inputs (the type of inputs that are usually red and white), then you'll probably need a stereo RCA to 1/8th inch adapter. Your best bet is just to get a good sound card with RCA inputs/outputs. Hope this helps!
