legionserial
Aha! Excellent point
Now we're getting somewhere
No as far as can tell (just checked) its not doing it with CD's, just mp3, wavs and such. So, I think we have nailed what my problem is. Now to fix it.
In addition, from a few tests I just did, there is a clicking problem in winamp, but its not half as bad as in cubase. Something else I noticed was that it wasn't changing sample rates as I played files with different sample rates in winamp. Eg, first I played 96khz file, looking at the control panel I could see it was at 96. Then I played a 48khz wav, but control panel was still saying it was in 96. Tried to change the sample rate, but had to close winamp for it to let me do that. Same for a 44.1khz wav. Then, while I was playing a 44.1 wav, I tried to change it and it wouldn't let me (of course thats not a problem obviously). I dunno what the hell thats all about but.....
After days, you guys helped me come up with an idea that I didn't think of..I also have a little old IDE drive in my PC as a backup install of windows, should everything else die. I put a bunch of wav files on there. Opened Cubase, opened a new project, stuck those wavs into new tracks (makinng sure NOT to copy it to project folder so that it would play from the IDE drive). Performance was waaaaay better. No pops, no clicks. Unfortunately my guitaring hadn't much improved since the last listen. Can we fix that now?
Not sure why it was working before and just packed in, but thats something I guess I need to look into...
So. We nailed it
I know what my problem is. Its my hard drives. Probably the RAID. So I'm going to take BushTheChrists advice and try putting my HD's on separate IDE channels. Is that possible with SATA? And how?
Thanks guys. I really appreciate your help with this. I have been to hell and back with this damn thing and you guys have just helped take a massive problem off my shoulders. Hell maybe I'm being a bit hasty, as it isn't entirely fixed yet, but I know its not my audio card thats screwed, and that the problem is much more fixable now that I know what it is thats probably causing it.
Many heads are more powerful than one and all that
Once again. Thanks. You guys truly are gods amongst men
So. We nailed it
I know what my problem is. Its my hard drives. Probably the RAID. So I'm going to take BushTheChrists advice and try putting my HD's on separate IDE channels. Is that possible with SATA? And how?Thanks guys. I really appreciate your help with this. I have been to hell and back with this damn thing and you guys have just helped take a massive problem off my shoulders. Hell maybe I'm being a bit hasty, as it isn't entirely fixed yet, but I know its not my audio card thats screwed, and that the problem is much more fixable now that I know what it is thats probably causing it.
