Obi-Wan zenabI
Active member
Ok, the studio is done, at least phase one...
Construction:
20'x30'X7'2" room,
oak flooring
open stairwell to cinderblock 2-car garage below.
5/8" Drywall over 1/2" sawdusty soundboard stuff
Functions of Room in order of importance:
Rehearsal space
Hi-Fi listening room
Recording Studio
I have a ton of books and several thousand records that must be put up there, and picked up six 3-foot-wide bookshelves to store everything.
QUESTION: I've put the shelves along the long walls in an alternating pattern, with each bookshelf facing blank wall opposite (see attachment). My idea is to reduce bare walls that face eachother to even the response of the room. Cheesy paint representation attached. The brown and black blobs are my big ol' desk, my rhodes suitcase, and my hammond.
Opinions? (before I load the rest of my books and records in...)
Thanks!
Edit: the little squares are my Thiels and my DCM time windows. Not sure where to cram in my antique B&Ws. (those are speakers for my CDs and records) Also, they are centered in the room in real life, and placed outside of nodes as per RoomModeCalc (not sure if they should be in the nodes or out after reading some threads here ) Listening seating is against the far short wall. Nearfields will go on my desk.
Construction:
20'x30'X7'2" room,
oak flooring
Rehearsal space
Recording Studio
Thanks!
I hope you know I was only trying to illustrate the concept, not to say books could not do the job if implimented correctly. But in reality, random arrangements do little for true diffusion. And even if you DO achieve a similance of a diffuse sound field, understand 2 things. Phase grating devices are ALSO 1/4 wavelength SILENCERS
Not to mention your room dimensions and absorption in the room will determine the decay rates of different frequencies, which has a bearing on the so called "diffuse" sound field. Even experts admit that measuring diffusion, especially in a small room, is a very difficult if not impossible task.
Not only that, but the room dimensions govern the lowest frequency you could possibly diffuse, if even possible. At least, thats my understanding.
