frank_1
I'm so tired, stressed and frustrated from this problem, that I can't even think properly
Here is the link: I posted this in the Cubase forum
Thanks for even looking in this link!
wheelema said:When I build PCs I always have the hard drives on the primary IDE channel with the drives set to Cable Select (CS), using a round IDE cable that defines the Master and Slave by their position on the cable. Likewise I always have the CDRW and DVD on the secondary IDE channel, with the drives set to Cable Select, yadda, yadda, yadda.
I do this because the cables just don't give you enough room to space the drives very far apart from each other, and the cases (given my experience) position the HDD mounts some distance from where you would be plugging in the CDRW and DVD. As a last resort you may consider swapping the mobo for something newer. As long as the new one supports your CPU and memory the cost would be fairly minimal.
Luck.
