D
downonthestreet
Just bought this drum machine secondhand through Ebay - it was made in 1990, but from appearances this one is in good condition. However...
When I first tried it out, tapping the pads produced sounds at the same volume as the preset patterns. Smartarse decided to wipe the previous user's patterns and songs to restore the memory to 100% and make a fresh start with my stuff. Since then, the pad sounds are way down in volume so that unamped through earphones with the big vol dial up full I can hardly hear them. Yet the preset patterns are still nice and loud, as they were before. I have been through the manual and set drum sounds to 99 vol, but this has made no difference. Any ideas from experienced users of this machine as to what I need to do to get the sounds and vol back?
Another query: I had an HR16 many years ago and was able to get dual channel sound using unamped earphones connected directly to the L and R outputs of the machine via a 2:1 plug converter (ie: one female socket connected to the earphone plug, which converts into 2 plugs that are connected to the female L and R Outputs of the machine). With the SR16, I can only get sound coming from the left earphone, regardless of whether I use the 2:1 converter plug or plug the earphones directly into either the R or L Output of the machine.
Would be grateful for any help/advice.
