Stef7
Hi all,
my MG1214 (bought used two days ago - for own usage) doesn´t record anything on any track (whether CH1-12 nor sync or Controltrack), while the playback works without any problems (even the Controltrack) .Technical seen it -must- be impossible that the entire recording head is defect, since each recording Track has -so seen- it´s own connector. When i set the tracks from "PB"to "REC", i´m also able to hear a "click" from the relay of the concerning track. The fuses right-handed at the device are all ok, the mixer also works. Noone also screwed on the PB/REC-Head.
So i think there are only two possible defects: The recording head needs it´s own voltage source (which i don´t believe) -or- the tape itself is defect. Therefore I am momentarily somewhat helpless.....
It would be great, if someone would be so nice and send me by email the Service manual for the 1214 - i´m not able to order it here in Germany, since no Akai support exist here
Many thanks!
Greetings
Stef
Many thanks!
Greetings
Stef
