Also some complain about not having 24 bit audio quality in tape based ADAT's ?
Yes it is partially true, but the SVHS ADAT machines can still record 24 bit recordings using a 24 bit A/D converter like the Behringer ADA8000. It comes with good mic preamps and A/D converters and has ADAT lightpipe connection for your computer sound card or ADAT machines.
If you use the ADA8000 to record into your ADAT XT20 for example, you can get very close to 24 bit audio quality, because only the last actual 3 bits are dropped off on a 24 bit recording. Which is very close in sound quality to 24 bit A/D and D/A converters. Some musicians say they can hear the difference, but on CD recordings you will not really hear the difference, maybe DVD audio, probably maybe.
Also 20 and 24 bit audio signal to noise ratios are much higher than 16 bit. So therefore, sampling at higher rates than 48 k will not increase your signal to noise ratio. Your higher sampling rates will sound a tad bit smoother in the high end, but at a higher cost to storage space and computing cycles/latency.
Your computer latency issues become very apparent at 96 k sampling rates, and especially the higher you go. When you process effects on your digital sound files your computer will slow down at higher sampling rates. So when down sampling for CD audio transfer, you are better off staying at 44 k , 48 k and or 88 k max sampling rates.
ADAT XT20 and LX machines still sound very good today, they are dirt cheap compared to the expensive plastic 8 track SD media recording machines that they have had for years now.
And ADAT tape machines have allot more professional quality +4 db and -10 db level INS/OUTS connectors that can be used all at once in real time for mixing and recording live 8 tracks at once. Get another ADAT machine for 16 tracks at once recording and playback and for bouncing tracks, for safety tape backups and also for 2 track stereo mastering.
And the ADAT A/D and D/A converters are still better than the 16 bit little plastic SD media recorders, and even some of the hard drive portable recorders that record in compressed 16 bit formats. Use ADAT instead, and even the old "blackface" converters sound better than the new little 16 bit plastic recording devices, trust me.
But are they more reliable ? Like everyone says, if you do proper maintenance on ADAT's, then they can run solid for years to come. Most used ADAT's have allot of life left in them, some can go as high as 6,000 head hours and most used machines have only
500 head hours on them or less !!! Especially the old "blackface" ADAT 16 bit machines seem to be a little more durable and long lasting with much fewer repairs.
I have recorded from a 24 bit A/D converter into a ADAT lightpipe of a "blackface" ADAT machine, and it actually sounded better than its own A/D converters even though it was recorded onto its own digital SVHS tape. So when I played it back through its D/A converters, it sounded very close to the original 24 bit recording. So even though the "blackface" is only 16 bit, the playback sounded even better than its own A/D converters because I used a 24 bit lightpipe A/D converter to record digitally into the 16 bit "blackface" ADAT machine .
But "Blackface" ADAT machines still using it's own A/D converters to record with still sound better than most CD players and DAT machines, so if your thinking 16 bit A/D sounds aweful, well give it a try and hear it for yourself. The 16 bit ADAT recordings have a nice almost analog warmth to the recordings. And I have heard other sound engineers say the same thing. I have heard allot of good sounding albums on "blackface" ADAT machines.
I remember allot of Jazz and rock GRP recordings that were made on the old 16 bit ADAT machines, and they sounded great !!!
I am super suprised at my old 16 bit ADAT tapes that bands use to record on, and yes they still playback perfectly today, and sound better than 90% of the CD Masters I have heard.
Everything made today is Pro Tools, and then Mastered with full Compression and Limiting, using a computer or hardware. And it sounds god aweful mostly !!!
Some newer albums in the past 13 years or so have hardly any real dynamic sound quality to them, and some recordings even distort the A/D converters on CD players and computers because the digital levels are compressed and limited way too high and beyond digital 0 db level !!!  I am not saying all album masters, but allot are this way and you can clearly hear it.
So yes you can get better sound quality than Pro Tools using even the old 16 and 20 bit ADAT equipment, if you know what you are doing in the recording and especially the mastering stages.
Just listen to your older CD albums 14 years or older, they have better dynamics and better sound quality than most of the new Pro Tools 24 bit loud compressed to hell and beyond digital distortion they are mastering today.
Absolutely retarded on behalf of all record companies CEO's that they think they will profit from the "volume wars" and sacrifice good sound quality ! And too not benefiting their own customers who actually pay their rent' !!!
Because mastering engineers are paid extra now to slam and fully compress and limit to hell the digital volume levels, to absolute maximum, and beyond, causing total crap loud volume and digital distortion with no real dynamics. And so yes the sound quality suffers greatly because of it.
Not to mention most people buying MP3's in a compressed crappy sounding format online, why not buy the actual CD instead, why not ? Because it actually sounds better !!! That's why........
Some of the mastering sound engineers, just to keep their Jobs have to listen to their retarded CEO's complaining that the volume levels on the Masters just aren't loud enough, absolutely Going against every good audio Law these mastering engineers were once taught ?!?
I am hearing some really compressed and really loud distorted and hardly any dynamics crappy sounding masters all in 24 bit glorious distortion for the past 13 years !!! And Yes I am
 totally pissed off because I have to hear these so called "24 bit mastered" god aweful sounding albums. Thank you record companies, is this why you are losing money ?!? I really think so'.
Sorry for the long rant....... I think I need a drink now and listen to my old ADAT recordings......
