K
Kcater
Thank you for adding me to this forum!
I'm hoping someone might pinpoint something or things I've got wrong.
The biggest issue is I'm capturing so much clicky clacky finger noise, and the actual harp sounds dull, fuzzy -- just not clear and resonant. It's hard to listen to.
The harp is strung with fluorocarbon, which is bright and resonant and highly sensitive.
Mics are matched Rode NT5. I've tried AB, XY and ORTF in every conceivable position: high, low, side, front, back, up, down, near, far....
Scarlett 2i2
Reaper
With the headphones I have been using, I did produce one track I thought sounded pretty good, but when I played it on other speakers, the sound was hollowed out and tinny. Played on my cell phone, which I know is going to be bad, it was unlistenable. People thought it was a harpsichord. Whatever I make, it's got to be somewhat OK on a cell phone, since that's what most people are using now!
I've also tried several rooms in my house.
In Reaper I apply very mild compression, gently EQ the bass for mud, add a reverb file that's pretty nice, and I've tried to EQ the clicking, but it's all over the spectrum. When I tried to use Reafir to cut out the clicking, it made other problems. I wasn't convinced that a noise reduction tool was good for the issue.
Is there anything that's obvious to you? I welcome your thoughts, and thank you!
Scarlett 2i2
Reaper
