I built the bass traps in all the corners, but now I need to build the absorber panels at the first reflection points. My question is, what type of absorber do I need to build? Mid-high, high bass, or other? Thanks for your help!
Depends on what kind of Roxul. If it's the 2.5-4lb it will work just fine. The 8lb can be a bit dense if you have a case where your reflection angles are real shallow.
