3' by 6' plate reverb build, use a transformer or DI box on pickups?
  • Thread starter Thread starter AnalogApples
A
AnalogApples
Member
I'm building a 3' by 6' plate reverb with 24 guage cold rolled steel. I'm going to use Lightning Boy Audio's suggestion of headphone speakers as the pickups. He plugs his "headphone pickups" into a microphone transformer, then into a preamp. I'm wondering if I can get away with just plugging the headphone speaker cones into a DI box that has built in preamps. I'd like to get the output of the reverb plate to the correct impedance and gain to plug directly into the effect returns of my Tascam m3500.
I'm pretty sure that I don't need transformers if I'm using the DI box with preamps. Can anyone here confirm that I don't need transformers?
A little more about the build: I ordered a Vidsonix Ghost transducer, which they even advertise as being great for making plate reverbs. It's a full range driver and only needs about 10watts. I have an antique Koss tube headphone amp that I'll be using to power the driver. I'll tension the plate inside a steel frame that I'm about to weld up. I think I've spent about $200 on metal for this project. The shop is welding triangular reinforcements onto each corner of the steel plate, for about $50.
Then I'm going to hang a piece of blue foam insulation parralel to the plate. There will be springs pushing the insulation away from the plate, and a wire connected to each of the two mouting brackets for the insulation so I can can pull the insulation towards the plate by taking up more wire. I'm not trying to keep the insulation laser flat, nor am I trying to keep it laser parralel to the plate. I figure if it's roughly paralel and roughly flat, it'll do it's job of shortening reverb times without me having to construct a robust elaborate contraption to hold the insulation. That'll also save a bunch of weight. I'll just have 2 smooth metal rods poking out the top of the frame. Then I'll glue a couple metal tubes to the top edge of the insulation, so the tubes will ride on the metal rods. A light spring on the rod between the frame and the insulation will make the insulation default to a far-away position. I can even run the wire up through the floor to my studio so I can increase/release tension to move the insulation and scare mice away in the basement.
I'm not married so my wife can't stop me.
