Saudade
Hi,
I use the tape deck to bounce mixes from my DAW and record it back. Recently I noticed a huge difference in levels between the L and R channels.
When I input to both channels at equal and constant levels (a sine wave loop at 1 khz), the deck meters (set to source) reflected L ch at -1 and R ch at -6 (dbv? dbu? whatever
) and my A/D inputs (roundtrip) reflected L -19.5 and R -19.3 (dbfs?).
When I engaged the monitor to "tape", the A/D shows L -16.7, R -22.6 (at 7.5 ips) and L -17.3, R-22.2 (at 15 ips).
I hope I am making sense here, I know this is a very unscientific way of testing, but I was trying to apply the naive and logical (to me) thinking that deck meters and my A/D should roughly show the same thing (which apparently doesn't) and that with the tape engaged in the signal path, the discrepancy is even larger.
So what is wrong here? Which part(s) of my deck is breaking down?
For the moment I can compensate by turning up the right (softer) channel, but I am worried if these are symptoms that some critical component is failing. Is there anything I can fix myself here? (a tape deck is non-existent here
I have already tested all other components in the chain, all cables are new, my soundcard inputs and outputs are alright. The tape used are new unused rolls. The heads and tape path are all cleaned.
) and my A/D inputs (roundtrip) reflected L -19.5 and R -19.3 (dbfs?). When I engaged the monitor to "tape", the A/D shows L -16.7, R -22.6 (at 7.5 ips) and L -17.3, R-22.2 (at 15 ips).
)I have already tested all other components in the chain, all cables are new, my soundcard inputs and outputs are alright. The tape used are new unused rolls. The heads and tape path are all cleaned.
