cjacek
Analogue Enthusiast
Beck said:Many people find that whatever they buy, they soon wish they had more.
Ain't that the truth!
audiophilez said:well, I guess I am in the market for a tascam tsr-8 or a 38, or maybe even a 4 track tascam if the price screams to be purchased. I take it tascam is a pretty solid decision, I dont know if I want to take a chance with otari, fostex.., I am sure they are great machines, but I know of many tascam repair locations. Again, thanks for all the help. I'll be "reel" crazy soon!
Guy Lewis
Hey, you also have TASCAM in Montebello so that should be real convenient for all your service, allignment and parts issues!
Beck said:There are no remarkable differences between these two formats. The Tascam 30-Series is a good example, as ARP pointed out above.
The listed specs of the Model 34 (1/4” 4-track) and the Model 38 (1/2” 8-track) are identical by the numbers. Technically speaking, the track width is marginally greater on the 1/2" 8-track by 0.003 of an inch.
Track Widths
Model 38: 0.039 inches
Model 34: 0.036 inches
For reference the standard track width for 2” 24-track is 0.040 inches.
These are all very close. The difference in track width between the Tascam 38 and a 2” 24-track is less than the thickness of 1-mil audiotape, such as Quantegy 407. As you can see the Model 34 is not much smaller. Track width alone doesn’t distinguish these machines from each other.
Other brands and models will be about the same… for example the Tascam 44 vs. 48, or Otari MX5050/8 vs. MX5050/4.
In general a ¼” 4-track will compare favorably with its ½” 8-track sibling in the same series, where electronics will be the same.
Be sure you really only need four tracks. Many people find that whatever they buy, they soon wish they had more.
~Tim
Not quite. I'd guess that the 1/4" machines you've seen are consumer models. Pretty much all studio or broadcast 1/4" machines are 7.5/15ips switchable.eeieeio said:Hey, I'm new at this stuff so please forgive me for butting in, but from my research most 1/4 machines run at 7.5 ips and most 1/2 machines run at 15 ips. Electronics and all else being the same wouldn't the speed alone warrant a fairly good step up in sound quality with a 1/2 machine?
Mark7 said:Don't the early Fostex 8 tracks run at 7.5 too?![]()
Mine doesn't. I don't know how early or late it is, but it's Dolby C at 15ips. It's one of the older designs, with 4 inputs and 8 outputs.Beck said:I think you might be right, but I'm not 100% sure. A friend of mine had the first version of the Fostex A-8, which came out in 1981. I thought it not only ran at 7.5 ips, but also had Dolby B, rather than C.
eeieeio said:Ok, I'm learning some stuf here!
Let me ask you guys this question. With all the talk about track width. Why is it that in the old days 24 tracks recorded on to 2' tape was mixed down to cassette tape and still it sounded professional?
jpmorris said:Ugh. I've never heard of anyone doing that, not that I know a great deal. Most studios that could afford a 2" machine used 1/4" or 1/2" for the mixdown, or failing that a digital format such as DAT, Exabyte, or PCM on videotape. Until everything went digital, 1/4" was the de facto standard. I can understand clients being given a cassette copy, but I really doubt it was used for the actual mixdown master apart from in small and home studios.
A Reel Person said:I'd have to differ with the previous opinion, (EDAN).
A 1/4" 4-track and a 1/2" 8-track should have the same overall fidelity *(AT THE SAME TAPE SPEED), with the obvious exception that the 1/4" has 4-tracks and the 1/2" has 8,... given that all other things are equal *(HEADS/ELECTRONICS), such as in a series of units like the Tascam 30-Series (32/34/38).
Without consulting the (Tascam) manual, (which I'll do later), the track width on the 1/4" 4-track should be virtually the same as the 1/2" 8-track. Also, the electronics of these (Tascam 30-Series) decks are virtually alike.
IF, by chance, you're comparing different makes and brands of recorders, then all bets are off, and they should be compared on a case-by-case basis.
F/I, a Tascam 38 won't sound quite the same as an 80-8, nor will it sound exactly the same as an Otari or Ampex recorder, although the track width & tape speed on these different decks should be virtually the same. At that point, differences in the heads and electronics will give a characteristically different sound for each deck.
So, given what you're comparing is not clearly defined, there's a lot of leeway for differing answers on general fidelity of units. I've framed my basic answer in a Tascam:Tascam comparison of formats,... but there's a lot more to it if/when you mix & match various formats and brands for comparison.
