0dbvu
  • Thread starter Thread starter djclueveli
About 20db.
0dbVU is line level in analog gear.
0dbFS is full scale (as high as you can go) in digital equipment.
0dbVU = -20dbFS
djclueveli said:
what is the difference between 0dBVU and 0dBFS?
It depends on your converters, but 0VU could be anywhere from -12 to -18dBFS.
That is to say, 0VU is zero "volume units", which is the passed-down-from-times-of-old term for the zero setting on any meter, whether it is a VU meter or not. So if your converter uses a "pro" +4dBu level, then 0VU=+4dBu. However, 0dBFS will be set somewhere north of that, to provide headroom. +19dBu is probably a rough average, thus 0VU would be -15dBFS in that case.
The only relationship between 0dBVU and 0dBFS is what you calibrate your converters to.
Mickster
Replies
7
Views
1K
Sky Blue Lou
Sky Blue Lou
subvibe
Replies
6
Views
1K
TalismanRich
TalismanRich
D
Replies
2
Views
8K
rob aylestone
rob aylestone
PorterhouseMusic
Replies
6
Views
457
PorterhouseMusic
PorterhouseMusic
