Stand on metal to ground myself instead of a hum eliminator?
  • Thread starter Thread starter Bargarcs
I'm coming in *way* late to this thread. My tuppence...
For the moment, let's put earth or ground aside. Think of your guitar as a radio. The strings are antennae, the pickups are the receiver(s). This is electromagnetic phenomenon i.e. RF. The pickup is essentially a transducer, insofar as it converts the electromagnetic energy (RF) from the strings and converts it to a voltage, i.e. signal. That "signal" then follows the signal chain. It's amplified through the chain, and ends up at your ears as hum. With a spectrum analyzer (free apps available for phones and tablets) you can identify the frequency of the noise. In the UK, it will likely be 50Hz with varying degrees of 2nd and 3rd degree harmonics. 60Hz in the US. The line frequency also has the closest proximity and the highest electromagnetic radiation (EMR).
The reason that putting your hands on the strings attenuates the noise is because your skin has a resistance, i.e. "R". Albeit a high resistance, >100k ohms/sq in/cm. It is this resistance that changes the essential "wavelength" the string is most efficient at receiving. (Think HAM radio, full wave, 1/2 wave, 1/4 wave/ 1/8 wave).
Bottom line is that ANYTHING that emits an electromagnetic field WILL interfere with your stuff. Everyone knows why "humbuckers" were invented.
Just my tuppence.
EDIT: Ever wonder why an acoustic guitar with a piezo saddle pickup doesn't hum?
EDIT: "Ever wonder why an acoustic guitar with a piezo saddle pickup doesn't hum?"
Ooo! I know sir! I know! It's because piezo devices are essentially capacitors and thus do not respond to electro-MAGNETIC radiation, transformers and stuff. They are sensitive to electro-STATIC fields but these are rarely found with any strength in normal situations.
Piezos CAN hum however as anyone who has ever tried to keep a Decca Deram PU cartridge quiet will testify.
Just a thought — could it possibly be interference from a Wi-Fi signal?
I once ran into a strange noise issue that turned out to be caused by 2.4 GHz Wi-Fi interference.
Switching everything over to 5 GHz Wi-Fi completely solved it.:-)
If you're referring to me, maybe it could be the wifi, the router is in the mechanical room which is also in the basement, so I'll be sure to check that.
Just my tuppence.
The thing is that the hum completely or nearly completely goes away if we move the guitar around to a different area of the room, or even just turn. It just so happens the the hum is in the exact place that he guitarist sits, and the direction that he faces.
Can’t you just rearrange the room? Short of that it’s very easy to just swivel the chair around to get to a ‘hum free’ zone.
Why exactly is the guitarist ‘forced’ to face the position where the hum is most prevalent?
All of us have faced this situation at some point and just moved into the ‘sweet spot’.
Just due to the size/shape of the room, the audio gear, backdrop, video equipment and so on. I'll have to see if we can actually do it
Sounds like you got a lot of stuff in a small room.
Good luck to you for what it’s worth.
Glad it helped!
Yeah, Wi-Fi can sometimes sneak into audio gear in weird ways — especially 2.4 GHz signals.
Let us know if switching or moving the router makes a difference. 👍
Glad it helped!
I call it wireless pollution. We’re surrounded by all kind of frequencies floating all around.
Older cell systems were real bad. I used to know when someone was calling before the ringer would go off. I’d hear a clicking through my stereo. And putting the cellphone near my guitar pickups gave me all manner of interesting sounds through my amp.
Right! And besides Wi-Fi, some wireless mics and Bluetooth devices also run on 2.4 GHz — that can add to the interference too.
Personally, if space allows, I still prefer using wired connections whenever possible. It’s just more stable and predictable.
I unplugged the router from the wall, and no change in the hum. I moved the guitar to various positions in the room, and the hum comes and goes without any apparent reasoning. I notice if I move the guitar close to electrical outlets, the hum gets louder. But the worst hum is about 1-2 feet in front of where the guitarist sits and it's not close to an outlet so that's strange. I'm becoming more convinced that it's something in the electrical wiring of the house, but I don't know.
Have you got light dimmers? They can generate interference, if they chop the voltage at a non-zero point.
In my place I completely rewired everything up to the current codes……. Electrical good.
I went one step further and installed all LED lighting. I still get a certain amount of hum.
Only solution for me is turning around and being positioned in the ‘hum free sweet spot’
We’re being constantly bombarded by various forms of electronic interference. I’ve just learned to live with it.
I don’t know if this applies to you, but refrigerators close by or on the same line can cause some hum.
no dimmers here, the refrigerator is on the floor above us.. I'm going to start unplugging everything in the house until something turns
I’m wondering — would adding a power line filter help in this kind of situation?
If the noise is coming from the house wiring, maybe filtering the AC line could reduce the hum.
The truth seems to be slowly coming to light — this thread is turning into a really valuable learning experience.(y)
Do you mean these things? https://www.amazon.com/Intelligent-Electricity-Voltage-Stabilizer-90V-250V/dp/B0FR8D5R64
You still have not located the cause. Until you do, you are just reacting to what you get. Treating symptoms, not cause.
I'm still trying to locate the cause. Do you have any suggestions on how to locate the cause? It wasn't wifi, or anything plugged in down here as far as I could tell.
We've suggested loads of techniques - gadgets, gizmos and even wandering around with a guitar. We have suggested turning off every item and energising them one by one. we have suggested so many things, but you seem to just introduce new material all the time and have not done, from what I read, any systematic, scientific procedural activity - just random this and that. You need to do this properly. taking problem equipment elsewhere to discount or confirm it is part of the problem. We have now no idea at all where you are in the progress.
