Tips to EQ and mix my first ever home-recorded song
  • Thread starter Thread starter amc252
A
amc252
Hello everybody,
I'm about to mix my first-ever home-recorded song.
Here's some info:
- genre: Mexican cumbia
- 4 tracks: voice, drums, bass, brass (trumpet + trombone)
- DAW: Audacity (plus any free Linux plugin I might need)
What I'd like to hear your two cents about:
- Tips to EQ each instrument
- Tips to EQ voice (cleaning Ts, Ps, and Ss, nasalness, etc)
- Tips to add reverb to instruments and voice
- Tips to EQ final mix
- Tips about how to mix the 4 tracks, meaning which levels would be best for each instrument and the voice.
- Any other advice you might think is valuable
I know it's impossible to give precise values, and I don't need an insane level of details, but I'd sure appreciate some starting points.
Thanks in advance for your time and expertise.
Can you post the track?
Agreed. There's no way to know what changes are needed. It's a bit like asking "what should I do to make my cooking taste better" without us knowing what you are even cooking.
I don't know, I only read but I think SUBTRACTIVE EQ is the way to go? That is, do not, if you can possibly avoid it , boost* any frequencies. There is also the "Skyline" principle where you visualize each instrument/voice as part of a cityscape?
*This can run you into headroom problems. The received wisdom is that each track should average about -20dBFS before you start messing with them.
-20dBFS!!! ?
Is this what people are doing since I've been away?
-20dBFS!!! ?
Yes because each time you mix two tracks at the same level the resultant is some 3dB higher. You can see therefore that as you mix more and more tracks you are going to bump into 0dBFS before long! Once you have EQ'ed and mixed the **** out of your tracks you can always boost it to as close to 0dBFS as you want.
0dBFS is also the highest level you can get out of an interface, equivalent to the maximum output of a mixer, say +22dBu and you wouldn't run mixer tracks at that would you?
Cubase certainly doesn't work like this Dave - in truth I have no idea how it actually works in the mix bus. Most of my individual tracks in cubase are sitting around -3 - and look right in the display, waveform wise. If they are lower than that for some reason (probably less care on the input gain adjustment), I'll normalise them to -3 too.
When mixing, few faders will be over 0, most probably between half scale and 75% I would guess. Only occasionally does the master need to drop, but if the bar has gone red, I will drop it, play the track again, and if the red over level bar does not come on, that's it. My monitor volume is never adjusted, and I use my ears for setting the levels. I could turn on the meter that tells me LUFS and other stuff, but I don't. Some tracks I do are quiet, and will be nowhere near maximum for the length - others will be louder and more continual. My old system of find the red light level and back off, still works perfectly well, and because I don't change the monitoring level, it seems to work. No distortion, but no massive attraction to a meter at all. I have no idea what the LUFS level is. Online streaming services probably mess up everyone's levels anyway. Oddly, my ultimate check is Spotify playlists - my stuff mixed in with other people's stuff in similar genres. If mine don't stand out as wrong, either too loud or too quiet, job is done. out of hundreds of tracks on Spotify, only one was wrong - a bit too quiet. I reworked it into a new track, and didn't delete the old one. Ironically, that track tops my list of shazzam'd tracks, every month!
Anecdote time - many years ago I was on a Soundcraft course. Students to real pros were on it. One was Big Mick Hughes from Metallica. One of the students from Liverpool's LIPA uni was totally spec-bound. He asked Mick what level he had FOH. Although clearly he knew, he sized him up and said "I turn it up till my teeth rattle" - the student said "what happens if you don't have enough sub-bass?". His answer was simple GET MORE!
I think I'm happy being not normal with levels. I just want faders with good travel, and no added distortion I can hear. It's very rare for Cubase to generate distortion from over loud individual tracks. I don't know how they do it, but it is not common at all.
Rob, you are the LAST person I am going to have a cow with about computer recording! I am but a worm.
I can only go by what I have read over many years and the whole thing is complex, involving as it does floating point math INSIDE the DAW which cannot I understand be overloaded? And the analogue world which certainly can!
That snapshot is of the Samplitude Pro X 6 demo tracks and you can see that each track runs quite low, certainly below -10dBFS (at which most peak) Some average a bit more than -20. I suspect the engineer was of the "neg 18" school? The master stereo output is crowding 0dBFS.
If you have say 8 tracks all peaking to -3dBFS then I don't see how you can bring anything up? To do so would mean bringing all the tracks down some dBs to "make room" for it?
And yes, stuff posted to streaming services will be forked about according to their personal proclivities but I would not know, don't have any chops to do that.
A few years ago, in forums people were saying, "Ooo! you must not record down at -30dBFS! Not enough bits and the results will be noisy and distorted". Or/and "Ooo! You mustn't record close to 0dBFS* your results will be distorted" We don't get such posts now . I think peeps now realize it is all bollocks!
*Mind you! That IS apparently true with a certain range of budget interfaces? I am sure that info will "ring a Bell" with many here?
RE: the raw mix snippet posted
I'm not at all familiar with the music style, so my opinions might be contrary to the norm. I think that the different elements need to be better balanced. I would bring up the backing vocals slightly, as well as the percussion. The horn and voice actually both are pretty natural sounding to me. Using some compression might help the balance but too much will take some of the life out of the sound. There aren't a lot of elements to work with, so just getting the right blending is the first goal.
I don't go crazy trying to get rid of every bit of sibilance, which is a natural part of a voice. If it's clearly distorting then it should be addressed. Sibilance is found in the ~5-10kHz range so putting a bit of a dip in the range can help if needed. I don't like taking out a lot of that range to limit .2 seconds of "S" because it affects the rest of the track as well. A de-esser compresses the signal when it detects lots of energy in that frequency range. Just like any compressor, use it sparingly. More is not always better.
The reverb seems to fit pretty well. I would imagine this music to be performed in a smaller venue, so using a hall reverb with a long tail might not be appropriate. If it was normally played in a cathedral, then a hall reverb might work.
I mentioned in another topic I was doing my first Hindu recording. A really nice lady turned up and we had a chat. We agreed an experiment was required to find out if what she wanted could be recorded and then progressed in little sections through the year. She had an ipad that produced drones on an Indian instrument I had never even heard of. Three strings. it also allowed other sounds - melodic and percussive to be added. I got the drone into cubase, and she selected A as a 'key'. The prayer she needed to record, over it was a part spoken, part sung prayer, but the words occasionally had a pitch, and the the singing revolved around the A, but were not in our usual Dorian, or any of the other usual scales. I didn't work it out at all. I heard 'th' type sounds, 'd' sounds and lots of mmmmmmm sounds. I explained that we could probably remove some of the sounds western music would consider mistakes or odd breath sounds but no - these were important and deliberate. It was fascinating - all my years of experience counting for nothing. The first test with an AKG 414 was considered a failure - it captured things she liked. Everything was reversed good is bad, bad is good, and as for EQ, every adjustment she liked what I considered the wrong way. Plus of course I cannot understand a word, apart from a word that said yogi - who I'm assuming is one of the Indian yogi wise men? As in the Beatles forray into Indian music. Then she mentioned she didn't like the sound of the droning sitar type instrument, and I loaded up an Indian instrument sampler - I'd never really used it. Her eyes lit up at the graphic images of instruments and she picked one - the drone sound she had on the ipad, but a sampled one - I thought I could just use this, but that instrument seems to have Keys, and different ways of playing that are totally outside my comfort zone. She played me a piece from youtube she thought was excellent and worthy of her attempting, but it started with drones and tablas - in my head was a rhythm, that she then chanted totally in a new rhythm. This is how it is done. I just have no frame of reference, and I just don't get it. She's promised to try to educate me, but for the first time, I feel totally out of water - I want to be able to help and assist, but if I cannot tell good from bad I am struggling!
Sure. Here goes a snippet of a very raw mix.
I think the percussion could come up a fair bit, and the main vocal down. But here's one general approach to mixing:
First, mix the drums. They are going to be the driving force of the song. Get each drum properly mixed and panned so that you can hear them all clearly and you're happy with the volume. The kick and snare should be panned centrally, other drums / percussion can be spread out a bit to taste.
Then, bring in a bass instrument, and get it to work with the drums. This should also be panned center. You may want to EQ maybe like a 100 Hz hi-pass on the bass so that everything below that is left to the kick. You may also set up sidechain compression on the bass to be triggered by the kick, so that the kick blasts the bass out of the way and they don't argue for frequency space.
Then your melodic instruments, like guitars and horns. These are usually panned off to the sides, maybe like 20-70% panning. These will usually take a hi-pass at 150-200 Hz to leave room for the kick and bass guitar. Probably just start with presets for your EQ and try to pay attention to what happens when you adjust the bands up and down.
Next, bring the vocals in on top. To make space for the vocals, you may need to adjust the EQ of your melodic instruments. Vocals should be panned center.
So at the end you would have kick drum, snare, bass, and vocals center. Panned around it are the horns, other melodic instruments, and maybe other percussion for effect.
EQ your reverb as well! I usually put like a 200-500 Hz hi-pass on the reverb.
Y por fin ojalá que esta canción no sea tan autobiográfica pero si es así te deseo mucha suerte en tu esfuerza de recuperarte. Escribiendo y grabando canciónes es muy buena manera de escapar de la realidad por unas horas y crear nuestros propios mundos. Ánimo amigo.
Thanks a lot for the detailed suggestions. Just what the doctor ordered. I'll do my best to put them in practice and post the results.
Muchas gracias por tu buenos deseos. Afortunadamente no tengo problemas con el acohol, pero espero que esta cancion de alguna manera ayude quienen los tienen y sus familias.
followed your suggestions and remixed the track.
Here is the new result.
I'd truly appreciate if you could take a listen and tell me what you think.
The mix is not getting in the way, but my biggest advice and encouragement would be to continue to explore your compositional style. (You said that this is your first home-recorded track, I assume you wrote the song as well?) I would recommend to work on hummable melodies and groovy bass + percussion lines before worrying too much about production techniques -- you will learn the techniques by necessity as you write and arrange more complex compositions. Honestly in this song I think the bass is doing way too much, I can't tell which beats it's supposed to be accenting or what general groove I'm supposed to follow. One way to think of it would be like, when am I supposed to tap my foot, or sway my hips, or nod my head? That's what the bass + percussion together should be telling me.
To use a popular example:
The bass is like, "1, 2-and 3, 4-and", so the whole notes on 1 and 3 give us kind of a break, let the rhythm breathe, give us time to sway to the other hip, etc.
Now, obviously, writing a song like Los Ángeles Azules is a lifetime pursuit, and maybe you don't want to sound like them anyway. What you have here is totally OK for a first recording! Just keep writing new songs and listening obsessively and analytically to the styles that inspire you most.
To analyze their mix a bit: you can hear the primary melody and keys C, the shakers more in the R speaker, while the hi-hat and other drums are panned a bit L, to give you a nice stereo image. (I think in cumbia, because there are so many different drums and percussion instruments, it's more common to pan them L and R than it would be with a standard drum kit.) The vocal "ah"s, synth, etc., are panned farther to the sides for width and to leave room for Natalia's vocals.
What instruments do you currently play? Did you record the instruments, or are they samples controlled by MIDI? I feel like learning to play the drums and bass and jamming with others have really given me a feel for this kind of stuff in a practical sense.
Y al fin hay que tener en cuenta que soy gringo y este estilo de música no es mi especialidad jaja, solo te digo eso como músico (pero he oído bastante música latino, no sé la demografía de este sitio pero imagino que he escuchado más que la mayoría de las personas aquí)
I will go with this. I think it sounds pretty cool, but I think the beats should complement the vocals a bit more. I would not wory about the mix as much as I would get the groove you're going for.
I do like it. If I could just find the groove.
One of the things with any composition, irrespective of genre is rhythm. This does not mean rigid 4 to the bar, and cross rhythms can be exciting - however, you have so many different rhythms going at the same time, it's almost impossible to tap your feet to, let alone dance. The first beat in the bar is vital and I'm struggling to hear it?
Looking at shmaller's video there, that band doesn't actually have a drummer, but a section of 4 or 5 percussionists.
I see hi-hat, timbales, kettledrums, and congas.
I think amc252's amended track seems to still have detached drums that don't seem to belong with the other parts. The backing vocals have some reverb, but not the drums.
I suspect that they are midi'd drum samples.
The main vocal seems more spoken than sung.
It is a very particular genre, which I am not accustomed to.
If you want to hear and see latin music done well, emerse yourself in Santana. Soak up some techniques.
For a first attempt, you're not doing badly.
Rather than polish the first attempt, you could try again and again and again, improving all the parts each time.
When you have something that sits together better, then look at tweeking and polishing.
Yeah, Los Angeles Azules are way more sophisticated than what I do. This is supposed to be a satirical song. "Chusca" would be the Mexican word I'd use to describe it. That's why I arranged it this way. There's definitely lots of room for improvement.
What you guys say about the rhyhtm is very important since I want the tune to be dance. I'll work on this aspect, trying ti improve the 'beat'.
This is a first effort both at composition, recording, and mixing. I created the track as MIDI files and rendered them with sampled instruments. I used Audacity for everything, really hand to mouth production LOL.
Yo tambien soy gringo y tampoco soy experto de cumbia mexicana. Pero se me hace divertido ampliar mis horizontes y aprender algo nuevo.
