Old Music Guy
Part 2: Use case.
1. Vocals: Check
2. Piano: Check.
3. Jazz: Let's start with this one. As a drummer myself, there are certain and specific sounds that I want from every drum and every cymbal. Narrowing it down, I want a very crisp, very quick, very short response on my snare drum. I also want to hear each and every "ghost" note I play. I play them for a reason,. A U47 is fast enough (I'd love to know how much faster the FET pre is compared to the 12AX7 or 12AU7), has the dynamic range (according to the specs). Then there is the issue of "top/bottom" mic. The U47, or any condenser mic for that matter, is 180 degrees out of phase with a dynamic mic. Whereas a positive "pulse" on a dynamic mic result in a positive going slope at output signal. With a condenser mic, a positive "pulse" will result in a negative going slope at the output and a miniscule propagation delay. Thus, if you put a close mic'd U47 on the batter head, and a dynamic SM 57 on the resonant head for example, the engineer needs to keep phase in mind.
One other thing that needs definition in recording it the "sound/response" of the stick tip on a ride cymbal. This is often overlooked. A well placed U47 should perfectly capture that as it falls in the 5kHz to 8kHz range with little attenuation. This is an often overlooked nuance that should be easily captured with a U47.
Everything else speaks for itself, with reference to the "inherent" compression characteristics mentioned about.
4. Rock. I wouldn't put a U47 anywhere near a rock drum kit. It would be like driving your friend to the airport in a Lamborghini when a Cadillac would do. Save it for the vocal booth.
Conclusion: I would be hard pressed to tell the difference between a Neumann U47 and a clone. I would have a hard time differentiating a AT2020 and a Neumann. I know a condenser when I hear it, but given the signal path from the diaphragm to the tape, I think that, given the economics, I would opt for 5 clones for the price of 1 Neumann.
1. Vocals: Check
2. Piano: Check.
