rob aylestone
Moderator
You’ve got some ideas, but some are a bit mangled. The real answer is simply to try them, listen and adjust and try again. Few recording people care a jot about strings. That’s a player thing. The recordist listens and thinks, wow, that guitar is bright/dull, I better try the XxX first. Like cooking, it’s adjust to taste. Remember that X/Y with the 90 degree, capsules close, technique is designed for stereo, at a distance, with wide sound sources. Two mics on a guitar is a blend. The dark, deep sound from the sound hole and the finger noises and the brightness from the neck. Spread the mics, use two stands or a cross bar it doesn’t matter. You just want the front of the mic to face the wanted sound, and get unwanted sound into its less sensitive side. That, you find out by experimentation, like how far away. Close might be good if the player plays with fingers or horrible if they play with a pick. Recording yourself is easier as you can change more things. If it’s great but just a little dull, then you can swap strings.Ok, so, I think I'm gonna go ahead and use the P170's for the guitar recording. I'm gonna run them through a Focusrite.
But that brings me to a couple of other questions:
Does string type/material matter with relation to microphone? In other words, would I use a different microphone on 80/20 vs Phosphor Bronze? How about for a 12-string?
I've bought a couple of sets of Martin's "Monel" Retro strings that I'm seriously considering using on this project. I also have some Aluminum Bronze and Earthwood strings. I was just wondering if the string material makes a difference in mic usage. I wouldn't think so but thought I'd ask anyhow.
Also, does anyone know where I can get a mic stand that extends to about 30 inches or so? I have one of those microphone "bars" that I can put two mics on (for the X pattern), but the mic stand I have is, for lack of a better way to put it, a "full size" boom-style mic, and I'd really rather not jack with it. I don't wanna spend a lot on it, but I basically just want something I can put in front of me at the right height, put the mics on it, and record.
it’s worth looking for Jimmy Quango’s recordings on here or YouTube. He’s found an ideal sound for his guitar and his playing. In his case, many times it’s a zoom with its X/Y mics, nothing clever. He found the right place, the right distance and it works. My guitar is rubbish sounding in real life, and my playing sucks. I have some excellent mics. Jimmy’s sounds better.
The secret is experimenting, NOT equipment. some of those fake SM57s are so close you can’t tell. I have one I keep a bit of red tape on for ID. Others sound like they are muffled and nasty. It’s a risk buying one. Do you feel lucky is a great question?
