rob aylestone
Moderator
I just gave the file a listen - like the others, the file reveals quite a bit, and your voice is actually fine. If you really want an ex-teacher comment, looking at the real detail, trying to find a problem - they're very minor. I can sing, but am not a singer. The tone of my voice is bland, and while fine for BVs, I am NOT a lead singer or front man. Your voice has qualities I don't have. I've a fair bit of experience of show type singers though. There are a couple of comments, and theyre not really about your voice, but what you do with it. Have a listen to your version and pick a couple of well known singers to compare things with. First comment - NEWS. Most Big Band singers change their pronounciation to create almost two syllables - ne-ous not a single consonant news. The correct one requires a 'kiss' stylepucker to the lip that starts just after the first 'n'. Many people actually pronouce news this way in speech, but most don't. For singing, you need to fix that. It's a singing thing that amateurs, strangers and even non-musical people will Zoom in on. Seems tiny, but it's one of those things you need to be careful of.
The other thing is you sang it with no track - perfectly fine - but did you notice you also changed key and managed at one point to be between the notes on the piano keyboard, sort of a half sharp or flat? It didn't matter for the clip, but would be something to keep an ear on if you didn't notice? In short - very little to even think about. If you want to sing this kind of stuff, your voice is well worth getting a proper singing teacher to give you a whirl - they'll teach you about breathing, and supporting your voice so you don't strain it. There is a decent voice inside you that a teacher could develop for you, because you can sing!
That genre of music is also from the period where singers started to really 'use' microphones. Your room is a bit small and boxy, so you need to find the best distance from the mic - which might well be closer in than you are using currently. This will increase the warmth and clarity - and make pop shields and control of the distance moe important. The proximity effect bass increase means really good headphones are needed so you can work the microphone effectively. Now we know you can sing, how about another clip with the back tracks you are using so we can see how your voice fits in there? If you do this, you will get from us suggestions about EQ changes, maybe compression and almost certainly suitable reverbs?
Rich's comment about the bass is important - crooners, which I suspect sums you up, need to control the bass - so headphones that are truthful down there are really vital (or of course, real speakers that sound good, in a good room - which you might find more tricky?
Don't worry about your voice - if it was crap, we'd have told you (nicely).
