A
alaurence
Hi,
I'm digitizing just over 100 cassettes for someone for archival purposes. I have an okay setup at home and they didn't want to pay for a premium service, so I'm charging a bit less to do it.
I've got some questions about levels.
First, my setup: Kenwood KX-550HX > Focusrite Scarlett 2i2 (using a dual RCA to 1/4 inch cable plugging into the input) > Ableton Live 10.
I also have the Waves WLM Plus metering plugin, and intend on using the Waves Restoration Bundle in post.
1. When deciding on a good level to set the gain on the 2i2, I understand this is a bit of trial and error, making sure the level is flashing green but not going into overdrive by hitting yellow and red. One thing I wish the 2i2 had was numbers around the gain knobs, so I could remember where I've set it for this work. Any suggestions other than drawing on it?
2. These are the levels I'm getting (and for reference I've got the gain knobs on the 2i2 set at about 11 o'clock):
3. Any other general advice when digitizing cassettes?
Thanks!
EDIT: Last question - I'm currently using the front inputs on the 2i2, but my dad has a 4i4 I could borrow. Would it actually be better to use the fixed-gain inputs on the back of the 4i4 instead of having to adjust the knobs on the 2i2?
- Hovering between -14dB and -6dB when looking at Ableton's built-in metering.
- When looking at the WLM plugin, I'm getting
- Short term: between -18 and -21 LUFS
- Long term: -20 LUFS
- Range: 7 LU
- Momentary: -10.1 LUFS
- True peak: -1.5dB
Thoughts on this? Obviously my aim here is to record this in to Ableton with as little tampering as possible, so I want to make sure it's not too high or too low (on the 2i2).
Thanks!
