TalismanRich
Perhaps the most effective solution would be a gradual grading from fibreglass to rockwool.
Maybe I should patent that.
Sorry, Raymond.... I'll SUE! (See post 56 above!)
I'll have my lawyer contact your lawyer......
The problem with the sponge analogy is that a sponge will saturate because the water doesn't change. WIth sound absorption, the sound energy is actually converted to heat. Unless you are putting kilowatts of sound energy out, it's not going to "saturate" to the point that you can even detect the increase in temperature.
Instead think of it more in terms of light. Things will absorb specific wavelengths of light, and reflect others. Those absorbed are converted to heat. A black curtain will absorb the majority of the light. A medium grey will also absorb the same wavelengths, just at a lower efficiency. White will reflect all wavelengths back. A red curtain absorbs the light but reflects back red. Likewise, certain materials are going to absorb different sound frequencies, based on density, rigidity, and thickness. The glass that is used to make OC703 would probably make a nice reflective window if cast into a smooth, very rigid plate.
The biggest problem for most people is that measuring sound is not as easily done and interpreted as viewing a room and looking at the light. It's easy to see that the corner is darker, or seeing a light reflecting in a mirror or off a window. Hearing bass bloom in the corner is the same as getting the reflection of a lamp in a mirror.
Putting up a thin layer of low density fiberglass for sound control is about as effective as putting up sheer curtains to keep the sunlight out of your room. Putting up a wall with mass loaded vinyl and rockwool panels is like adding thick blackout curtains.
I would say that light is closer a analogue in that it a wave, just at a much higher frequency. However, I will admit that there is a difference in the conversion mechanism from sound. With sound waves, the degradation in level is mostly due to vibrational friction creating heat and reflection is simply of a portion of the wave that could not be converted to heat bouncing back, similar to a mirror. With light, the reflected color actually is due to the light's energy causing a jump in electron energy level of a specific portion of the compound, and the resulting return to the previous level. Absorption is simply converted to heat.Ok, lets take your light analogy. A light absorptive material will only absorb a portion of light and reflect the rest. Simply stated a surface's ability to absorb light is finite. Does that really change the analogy though? Both analogies are off as light is both particle and wave and water is a liquid which is different from sound waves transmitted though air molecules. I chose the later for simplicity but neither is a direct correlation.
I completely agree that, given a particular material, having a thicker section with more ways for the sound pressure to be dissipated is the way to go. Based on the the modelling, I would expect you could calculate how to equate the two different materials to get the same amount of sound dissipation.You seemed to miss the more relevant point, that with sound energy, an absorptive material will become reflective at some point which is dependent on the sounds ability to pass through it in order to be converted to heat. If it can't pass through, it is reflected. This is especially prevalent with lower frequencies, which is where most are in need of treatment.
Well the "pink" stuff I refer to is just normal house insulation. Depending on product, the GFR rating varies for a whole bunch of reasons. To explain it further, I'll stick with the Light analogy to make Rich happy.Would this apply to the normal house insulation as well? Meaning that normal house insulation at a certain thickness is just as efficient if not more?
Or am I misunderstanding this?
I don't know where you get the idea that I said anything about squashing it down. I am only talking about the thickness of the various material used. You can get insulation in a variety of thicknesses and also you can stack them together to make absorbers even thicker. GFR is a material construction specification and is not dependent on thickness. It is also the rating of the insulation when fully expanded to its proper dimensional size. R30 is 9.5 inches for instance. Compressing it would change the GFR.Ok and I am not disagreeing, but I have used normal household insulation and Rockwool RW3 acoustic. The acoustic is made differently and denser. They also say that household insulation shouldnt be compacted otherwise it loses its insulating qualities. But are you saying if we get household insulation and squash it down and even add more, it will be just as or better than acoustic insulation?
Thats a simple one. I came here and read the posts on which acoustic insulation to use available in my country.I don't know where you get the idea that I said anything about squashing it down. I am only talking about the thickness of the various material used. You can get insulation in a variety of thicknesses and also you can stack them together to make absorbers even thicker. GFR is a material construction specification and is not dependent on thickness. It is also the rating of the insulation when fully expanded to its proper dimensional size. R30 is 9.5 inches for instance. Compressing it would change the GFR.
What I am saying is that density is not the most important aspect to absorption. How well sound penetrates and is absorbed, without being reflected, is what is important. Gas Flow Resistivity aka the ability for sound to penetrate. We are talking about sound waves traveling on air molecules. Once those sound molecules hit sufficient resistance of the insulation, it acts as a solid surface and is reflected. How thick depends on the material. For really thick bass traps, lower GFR materials like pink household insulation will out perform higher GFR and more dense insulation like rockwool. Somewhere at a thickness in between, the rockwool will outperform at less thick low GFR insulation. How do you know which and what to use for a particular application? Run the numbers and compare.
Question, how did you know Rockwool RW3 Acoustic would be effective for your sound treatment requirements? What data did you use?
Sound travels in everything. It travels well in water, as any whale will tell you. It is discontinuities that cause reflections. i.e. a change in the densities of materials.I have also tried to work out that sound only travels in air.
And companies that deal with acoustic treatments use a bit of science and engineering. Reputable commercial acoustic treatment manufacturers do something called lab testing of their products and publish the data so that the buyer has an opportunity to evaluate the efficacy for their acoustic issues. All these materials have a range of effective frequencies, yes, even foam. The question becomes, how wide a range of frequencies do you need to solve your fundamental problems?Thats a simple one. I came here and read the posts on which acoustic insulation to use available in my country.
I have since found out that companies that deal in acoustic treatments use a variety of other materials and methods to treat room acoustics. Even foam which is scorned on here.
I know that RW3 is made different than fluffy stuff, so I assumed that was the answer, but must admit expected more of a eye opening difference between the two when being used. I was disappointed.
Apples and oranges? My discussion is only focused on acoustic treatment, not construction which really for most, is another topic. Many here are trying to utilize an existing space for recording. Is it still all really just dumb luck?I think most of it is dumb luck. I've been reading about it since around 1980. I've taken all the successes on board and in the main, avoided the things that caused others problems. In addition, I've looked for ways to remove problems caused by construction too hard for me to do properly. I have a list of always do, try to do and avoid. Sometimes you are forced to cut a corner, and over the years I'm better at assessing how damaging it will be!
You are hitting all the nails on the head with 100% accuracy. I could build the studio but for the insides I came here for info.And companies that deal with acoustic treatments use a bit of science and engineering. Reputable commercial acoustic treatment manufacturers do something called lab testing of their products and publish the data so that the buyer has an opportunity to evaluate the efficacy for their acoustic issues. All these materials have a range of effective frequencies, yes, even foam. The question becomes, how wide a range of frequencies do you need to solve your fundamental problems?
Seems to me anyone who builds a studio space is recording and mixing audio. It seems rather obvious that one should have a basic idea of audio spectrum in applying EQ and mixing various sources. I'm trying to gently ease into this question. How did you determine what frequencies you need to treat for in your studio space? How did you evaluate these two products, at the thickness you used, as to how they would perform?
You say you were disappointed. What were you expecting, magic? I know I'm walking a line where I could come off as being overly harsh. Sometimes the most obvious problem like flutter is masking other issues. Many who have been through this know the rabbit hole it can become. Yes, for some it can be a little overwhelming.
This is homerecording.com where gathered are those who desire to be musician, songwriter, producer, engineer and for many, at least rudimentary studio builders. If someone told you that if you want to be a songwriter, that it requires effort to learn the craft, most would have no issue with the advice. Is it not the same for those who wish to acoustically treat their studios? If I say you probably want some basic understanding of the problem is that too heavy an ask? DIY can yield great results but that is totally dependent on knowledge, otherwise you are depending on just dumb luck.
The proof is in the pudding
Sure...if that's what you want? Many studios have live rooms. Not exactly dead. An example would be a big room for piano or cello. Even acoustic guitar in a great sounding room, man is there anything better in life? Sadly, most of us, including myself don't have such a space. I did classical recording professionally. There it is all about the room.You are hitting all the nails on the head with 100% accuracy. I am a carpenter who throws a hammer at nails and sometimes gets lucky. I could build the studio but for the insides I came here for info.
Yes I expected magic from RW3. I lined the inside of the sound booth with acoustic foam tiles. I think 250 of them. Then I inserted bass traps in each corner then later I hung 4x2ft RW3 panels over the foam tiles. It works for us. It produces a nice flat sound booth to record vocals.
The other room I assumed that just hanging RW3 panels on the wall and ceiling would do the job for video. A much bigger room. It did nothing and Rob's suggestion of duvets all around as well actually did the job.
Conclusion...........RW3 does work, but only if it is around the room 100% or used with something else making the coverage 100%. Hanging pretty panels every now and again does f*ck all but waste time and money no matter where you position them. The sound has to be captured to reduce reverb. Anything it can bounce off it will.
I am sure you will agree?
When the room causes problems with the mic sound, then I have no choice and that was with 3 different mics.
