What can I do to improve my mix on this song?
  • Thread starter Thread starter MMxL0neLy
MMxL0neLy
MMxL0neLy
Trying to figure out what I can do to make it sound even better I recorded the vocals and mixed and mastered it myself.
The microphone used was the SM7B running into an SSL 4000 E Channel Strip Pre
Other than that any feedback would be great only looking for mix and mastering advice
Just a Demo Song Work in Progress
WAV Version
Updated Version
Sounds pretty good, but I'm hearing it a bit off center.. it's sounding a little heavier on the left side.
Definitely, I should add more volume to the right band on the multiband to make it more balanced thanks a lot for your quick response, and thank you for the feedback.
Sounds about right. If I got a mix this far, I'd be packing up and going home.
Certainly a nice sounding production. Deep, clear, rich, warm. Nicely done. (y)
Means a lot to me the mix is sitting just right but needs some more work for sure ?
What do you mean? If it's sitting just right, it doesn't need more work. You talking about mastering?
Was that Autotune that the vocal went through? Or did you use a different plugin?
You've got this right in the pocket.
Any changes you make, only you will know.
WAV Version
You've done a good job so far - as far as critiquing the mix - you are a little shy on the lower frequencies - they are smooth - but I want them more prominent.
Then your upper mids are bit subdued - although that is probably your mixing choice right?
The upper mids are a bit subdued I've already gone back and smoothed it out and for the low, I tried not to mess with it as much but may have to see what small changes I can implement thank you.
