It's a close call. I can't tell if I'm imagining it or it has been suggested by your comments, but the second one "may" be a hair brighter - and that's based on it's matching run in the lower key. In a mix with hardly any EQing, either would sound the same, IMO.
listening to it today its subtle. theres a little more treble, but if a drummer was hitting cymbals and other noises going on...its pretty small difference isnt it?
Its a simple riff....AA- C-d-d#-E..(stock) ...AA -C E-d#-D (SPB3)...then repeat...
I heard a lot more differences in the string samples upthread, than I did in this pup swap.
Doing the Guitar Setup closer inspection today, it seems if I set this Squier Affinity lower like the dude says, theres a bit fret buzzing, or a lot.
Im whacking it with a pick too, but these are .100 strings or lights and they are set pretty high the Low E.
My Squier Jazz is so close to the frets but it doesnt buzz as much.
Total hobbyist novice here on Pro Setups....but the neck bow seems high, string height high, measurement at the nut is ok (but there is some ringing on the A string and if I put my finger on the string by the A tuner it goes away? the other strings dont do that). Setting the pickup height I already did using my ears and VU meter on my sweet ISA 430 preamp....its the VU meter. glow..
ADD: weekends past update
So I ran into a deal of another US PBass 2011, beauty mint , case, and all candy like NOS...same original strings, few hours , a closet one the dude said.
Original Fender setup.  I played it and of course is a beauty, 2011- rolled edges, etc...etc...
Plugged it in and smooth player, then the sound and VU output, and then out came my steel ruler and all was setup very much identical to my Squier PBass....pickup height 3/32 , string height....etc..  both pretty much the same.
So if the US is a 10 star as the scale to compare to. The Squier Pbass, post setup and all the above holds up amazing well.
In playability the Squier might be a strong 7, if an easy player an 8.  7.5 star..
In sound, the Squier pups might again be 8..9 or 10.
In hardware, Squier tuners and bridge a bit lower, less mass, less smoothness 6?...5?..6....
In cheap-cost Squier at $150 used is 10
In Decal buzz 7, maybe this one a 6 because its not even the "gold" decal...but its a 20th Anniversary neck plate! +1  ?
In materials of neck Rosewood and Alder body....8
In workmanship, 2002 Squier PBas seems nice, but like so many others note, the higher frets (most dont use) maybe buzz more...7 fret work.
Then I liked what one dude did in his video compare. He pie/charted the cost.
This US was $1025.  Lets take $250 for the mint Fender case and 100% candy....So guitar is $775, this is swag goof cost numbers.
How much for the added quality tuners and bridge? $150?  and then the Holes through the Back is labor and cool...$100..$80?
So theres an added $230 in hardware and holes through the back. Bringing the guitar difference to $545 ish.
Now the rolled neck, perfect fret work I have to give it $200 as if done by a luthier setup....  $345 left to explain.
Resale of the Decal worth $300..lol...thats what the youtube dude said.  I have a 0% Paypal, but I dont think I would pay $1800 or even $1500.
Im old and its just getting to be more Antique Collector Roadshow prices than it is making music....and its money.
However sound wise there wasnt a lot of difference at all. If my sons punk band are going to bang stuff, or if I want a Bass
to play and lean against a wall and dont care attitude vibe,  not-me- worry about scuffs and dings....Squier PBass kind of wins, imo.
It is again very eye opening to compare one side to side....having a $150 used Squier, I might even watch a video and learn how to
do some fret work at the 17th and on frets...even though I dont use it down there.
As for my 30yr Squier Jazz, its a 10. I dont know why, came off the factory floor that way. ?
This 2002 Squier P-Bass...is an easy 8....for $150, and Ive had US Fenders rating lower in the past.
Its been fun, 2002 Squier Pbass... enjoyed the comments too..... GHS Brite Flats, and all the youtube Guitar setup time is so good to have!
My Squier is within 1/32 of the US setup PB, I think that makes a huge difference.
