R
Ron Rondondo
Ok I'll check it out thanks.
I just checked there is no listing for USB driverOk I'll check it out thanks.
It is disabled.OK I'll check and see, thanks much
It is disabledThis has to be in Windows settings. Under System : Settings: Sound: Input Devices : Manage Sound Devices, you probably have something in Realtec Mic Array, or whatever Dell is using for the laptop mic. Disable that in Windows, it should be greyed out, and won't be active any more.
Go to the pv website and download the driver for your mixer and install it on the laptop. Then you should see it.
Ok absolutely will do, and thanksGo to the pv website and download the driver for your mixer and install it on the laptop. Then you should see it.
There are no drivers for the 10 AT mixer in the Peavey websiteGo to the pv website and download the driver for your mixer and install it on the laptop. Then you should see it.
Is it possible I can receive your advice on a problem I am having sir ?Thread moved
Sure.Is it possible I can receive your advice on a problem I am having sir ?
Thank you very much I have solved my issue thanks to all you folks here. You guys made my night !!Sure.
Others have said this already, but first thing is to go to Windows sound seetings and make sure the USB device is selected as default input and out. Then do the same within Reaper.
After looking at the manual and a few other places, it seems it doesn't have a driver. So this will be a computer system configuration issue.
This might help. It appears that some themes don't allow the meter colors to change. You'll need to edit the theme.Thank you very much I have solved my issue thanks to all you folks here. You guys made my night !!
Are you familiar with Reaper by the way, and if you are I have one more question:
I'm trying to change the colors on my VU meter/s but for the life of me it will not let me do so, I want lower green, middle yellow and clipping red but all I can get is orange
got any suggestions please?
Thanks very much for your suggestion I truly appreciate it. Now allow me to give you a good tip. Most musicians now days (you may not be included) are of the mindset that more is better in every way. More instruments, more effects on top of each other. Music has become extremely mechanized since the invention of the synthesizer. When you listen to recordings you hear a pristinely done musical arrangement with every instrument in it's "perfect" place. Young musicians have been brainwashed into this mindset, whether it was intentional or not, personally I believed it simply morphed in that direction.Glad you got it figured out. I suspect "High Definition Audio" is the name of the internal sound card of the laptop. Mine is called Realtek High Definition Audio.
Maybe check out the mp3 clinic where people post things to get other people's feedback.
