androo235
Yes, I know, this is years, three decades actually, on from the launch of the SR-16, but here goes. I have an SR-16 and I want to use it as a sound module driven by a sequencer in my DAW (Reaper). In theory I know this is possible as the 1991 video with Craig Anderton says you can use it as an "Expander Module" and so does the SR-16 manual, but neither video nor manual tell you, in detail, how to get it working. I have a Behringer UMC404HD interface which has DIN-Midi in and out/thru as well as a USB B interface to the PC, I also have an X-Touch control surface (CS) which too has DIN Midi in and out/thru as well as USB B to the PC and 2 USB A for devices. The SR-16 itself being vintage (even though I bought it new only a few years ago, yes, I wish I knew then what I know now, but, hey it's here now and I want to use it) has only DIN Midi in and out/thru as well as audio outputs (up to four, I'm using two). I have become fairly familiar with the SR-16 menu's and have been able to get the DAW click to drive the SR-16 or the SR-16 click to drive the DAW (which some have had trouble with), but, that isn't what I want. I have done that connecting the SR-16 via the interface or via the CS. So, although I can get the click to work in either direction either of those ways I can't get the SR-16 to respond, at least not audibly, to the DAW sequencer. I can see the Reaper track VU react apparently based on sequencer input but can't get any sound out, unless I hit the SR-16 pads. I hear those, but, they don't drive Reaper sequencer input and sequencer input doesn't drive them. Connected via the interface or the CS the SR-16 doesn't show up in Reaper's preferences as a midi-device. Maybe it's because I haven't got the settings right in Reaper which are, albeit very flexible and comprehensive looking, also somewhat confusing for a newcomer to life with a DAW (and midi, albeit that I've read a lot about it and been aware of it for 40 years or more). On the other hand maybe it's because I'm having to connect the SR-16 to the PC indirectly either via the interface or via the CS. So I'm getting a Midi DIN to USB cable so that I can connect the SR-16 directly to the PC, maybe that will solve the problem (but, I have to say, I thought that was the point of the interface and the CS that I have having the DIN Connections....). Any suggestions or encouragement welcome.
I've also tried, with different cables, swapping in to in for in to out, out to in etc. Perhaps I'll need a little spreadsheet to make sure I've tried every permutation.
