androo235
I have already posted to an old thread in another forum on this site about this and also started a new thread in a different forum, both before I noticed this forum. Well, I know it probably isn't protocol to post essentially the same thing, albeit, edited a bit to be more relevant to the specific forum, in three places, but, I'm going to do it anyway, as my problem, could be my daw, it could be midi settings or it could be the SR-16 itself and the three places (with this post) that I'm asking cover that spectrum. If this is seen as "spamming" then fair enough I'll have to choose just one place (probably the midi forum, probably got a higher geek count there
). So, here it is, slightly modified, again.
Yes, I know, this is three decades on from the launch of the SR-16. But I have an SR-16 and I want to use it as a sound module driven by a sequencer in my DAW (Reaper). In theory I know this is possible as the 1991 Craig Anderton video says you can use it as an "Expander Module" and so does the SR-16 manual, but neither video nor manual tell you, in detail, how to get it working. I have a Behringer UMC404HD interface which has DIN-Midi in and out/thru as well as a USB B interface to the PC, I also have an X-Touch control surface (CS) that also has DIN Midi in and out/thru as well as USB B to the PC and 2 USB A for devices. The SR-16 itself being vintage (though it's a 24 not a 16 bit model) has only DIN Midi in and out/thru as well as audio outputs (up to four, I'm using two). I have become fairly familiar with the SR-16 menu's and have been able to get the DAW click to drive the SR-16 or the SR-16 click to drive the DAW (which some have had trouble with). I have done that connecting the SR-16 via the interface or via the CS. So, although I can get the click to work in either direction either of those ways that isn't what I want. What I want, but can't get, is the SR-16 to respond to the DAW sequencer. I can see the Reaper track VU react apparently based on sequencer input but can't get any sound out, unless I hit the SR-16 pads. I hear those, but, they don't drive Reaper sequencer input and sequencer input doesn't drive them. Connected via the interface or the CS the SR-16 doesn't show up in Reaper's preferences as a midi-device. Maybe it's because I haven't got the settings right in Reaper which are, albeit very flexible and comprehensive looking, also somewhat confusing for a newcomer to life with a DAW (and midi, albeit that I've read a lot about it and been aware of it for 40 years or more). On the other hand maybe it's because I'm having to connect the SR-16 to the PC indirectly either via the interface or via the CS. So I'm getting a Midi DIN to USB cable so that I can connect the SR-16 directly to the PC, maybe that will solve the problem (but, I have to say, I thought that was the point of the interface and the CS that I have having the DIN Connections....). Any suggestions or encouragement welcome.
