C
		CaseyCayce
I’m struggling with monitor calibration and need some direction.  I’m using KRK Rokit-8 monitors that have a HF Adjust and LF Adjust on the back.  Those adjustments have little effect on this issue I’m posting.  I have a pink-noise track in Pro-Tools that gives an EQ reading of a normal, steady, slightly ascending slope from low end to high end.  Using a measurement mic, I’m getting an EQ out of my monitors with a distinct low-end drop, like an HPF is being applied.  The signal is going straight out of Pro-Tools through my Presonus 32R for this test, totally dry.  As a second test, I loaded the pink noise file into iTunes on my Mac, disabled the iTunes EQ, ran it out of the headphones jack and into the KRKs, getting the same results.
I’m not so thoroughly versed on monitors, but my expectation is that they’re supposed to give me back exactly what’s coming out of my system, am I correct on that? If I mix based on the HPF curve of these monitors, aren’t my mixes are going to come out more bottom end than I want?
See the attached image for the source and monitors EQ readings.
Could use some help on this one.
Thanks.
Thanks.
