S
seankerns
Member
All right. I'm apparently old. I've never seen that.Happiness expression bro
"Almost the same"?Thank you again and I'm happy to say that none of the problems you mentioned earlier are there ... only the belt ... I'm lucky enough that today I found a belt at a local store that is almost the same .... it's doing its thing and I'm happy but I will confirm the good functioning of it only when I got the tape and do recordings ... Thank you All for the great help...
yes it's the same length and thickness as well the material is ... the only difference is the large of it wich is 5 mm as opposed to the original that is 7 mm ... by the way, these are the measurements i've made of the original belt in case any one need it : 360 mm tall - 7 mm large - 0,9 mm thickness"Almost the same"?
As long as it works. Should it not last, the original type is available online for not much money.yes it's the same length and thickness as well the material is ... the only difference is the large of it wich is 5 mm as opposed to the original that is 7 mm ... by the way, these are the measurements i've made of the original belt in case any one need it : 360 mm tall - 7 mm large - 0,9 mm thickness
Just checking, is it the same diameter as the old belt is now, or did you take into account that it was originally smaller when it was working?yes it's the same length and thickness as well the material is ... the only difference is the large of it wich is 5 mm as opposed to the original that is 7 mm ... by the way, these are the measurements i've made of the original belt in case any one need it : 360 mm tall - 7 mm large - 0,9 mm thickness
I took into account the expected difference...Just checking, is it the same diameter as the old belt is now, or did you take into account that it was originally smaller when it was working?
Thank you ...As soon as I receive the tape I will post a video hereSo - we're all waiting for you to tell us how well it records ........... We can only get excited when the tape moves and music pops out!
No , i just run the master trough the tape .... the original session is lostSo, did you completely re-record that song, track by track, on the tape machine?
Thank you, I'm very happy and the tape is factory calibrated and very good ... I didn't use the Dbx yet because the noise floor is down low...Congratulations on your new purchase. Seems quite rare. It should be tip-top with a minimum of maintenance. As well as the belt and verifying the lube in the solenoids hasn't hardened, I believe the R/P levels will need to be trimmed up after so many years, but that would be common and expected. I had a TEAC Pro tell me once that the dbx and bias are stable, so don't f#ck with them. I proved that out once on a 34B. After tinkering around with bias for hours, I ended up exactly where I started. I should have listened to Jim, he would not steer me wrong. I would not touch the dbx unless I heard audible mistracking. Enjoy!
