N
nicoroxlm
Up to date drivers firmware and latest reaper version
With enabled inputs first 1 in 1 last 8 in 8
channel 1 shows a check mark in channel one in mono the remaining channels present without a check mark
channel 2 shows a check mark in channel one in mono the remaining " " " " " "
channel 3 shows a check mark in channel one in mono also same as above
and so forth
BUT RECORDS THE MIC INPUT OF CHANNEL ONE IN ALL 8 CHANNELS !!!??
With enabled inputs first 2 in 2 last 8 in 8
Channel 1 shows a check on channel 2 no check on the remaining 8 but channel 1 does not appear
channel 2 shows a check on channel 2 no check on the remaining 8 and channel one does not appear
similar for the remaining 3 thru 8 channels
BUT RECORDS THE MIC INPUT OF CHANNEL 2 IN ALL 8 CHANNELS INCLUDING CHANNEL 1
This same pattern continues for enabling beginning with channel 3 and so forth to channel 8
What else to try seems a software issue??
and so forth
