A
audiopro
Hello,
This is a question for professional folks who have some experience with this type of thing, and I think there are probably plenty in this forum who will understand the question.
I am having a shed built on my property, for my studio / Tiki bar / musical adventureland / whatever. : )
I am probably going to use Tuffshed to build the thing, because they will actually assemble it all on site and handle the subcontracting and so forth.
The standard sidewall heights for the type of building I am contemplating is 8'1". You can add up to 5' of additional height, in 1' increments, but its expensive.
The two roof styles they offer are Gambel and Gable.
I asked them about a structure 24' wide and they say they can do it with scissor trusses and no "bottom chord". I'm attaching a drawing they provided which illustrates the two different roof styles with the scissor trusses and some area calculations.
Now I want really high ceilings, and I'm trying to decide which way to get them with the least problem / expense.
The Gambrel roof scenario is quite a bit more expensive than the Gable roof, but it provides quite a bit more clear height, although the width of the room would diminish as it goes higher. Using the Gambrel roof may be cheaper and even better than adding 5' to the sidewalls on a Gable roof building.
The scissor trusses don't really bother me in this scenario. I don't really think they are going to be much in the way of anything. So, I'm thinking of just leaving the whole thing open and then treating the space it as it needs it once its built and measurements can be taken.
I'm looking for opinions on whether or not the "extra height" provided by the Gambrel roof style is just about as good as actually having taller sidewalls. It would be even higher [but narrower at the top] than adding 5' to the sidewalls and using a Gable roof. But the vault under the Gambrel roof does narrow as it goes up [because it tracks the roof], whereas actual extended sidewalls would go straight up [but not as high].
Either way, its not going to be a flat ceiling.
Hopefully this makes sense.
Thanks in advance for any expert responses.
Best,
audiopro
Best,
audiopro
