B
Bulls Hit
**Edit** Thanks to everyone who's had a listen and shared their comments. I've put together another version based on the same jam but with a different arrangement. The 2 drum grooves in the original (v2) went together OK going one way but didn't really transition well going back so I've removed the 2nd transition and shuffled things around a bit in v3. No other mix changes except making the kick slightly more present - it's still got the wet blanket all over it! Does the new version hang together better than the original?
My old Fender amp finally made one farting noise too many so out it went and I picked up a 2nd hand Line 6 Spider.
Always interesting what a new piece of gear brings to play and there seems to be some good tonal variation with this unit.
This is the first jam with it - interested in how the mix balance translates for you or any thoughts at all..
Cheers Gonzo
