willmarshall
Hey guys,
I'm in the process of building a new home studio / mixing room, and I'm trying to reduce background noise.
I live in a quiet, pre-war brick apartment building in Brooklyn. The walls are 14" brick, and the windows are all brand-new, double-glazed, tightly fitted beautiful things. I have no traffic or street noise, and no bleed inside the building, since the internal walls are all brick.
There's only one problem: my neighbours have an old air conditioning unit in the light well outside my studio. The windows block most of the noise, but there's a peak at 260hz coming through the window at about 39dba. The sound bleed is totally localised to the window - there are no other gaps, vents, etc in the wall whatsoever.
I'm researching and pricing up my options for further sealing the window. So far my options are:
Making a DIY window plug is my "nuclear" option, but I'd rather do something more elegant. My cheapest option is curtain (I can use their standard size), but I'm not sure how well it will actually work.
Does anyone have a sense of how well each of these options is likely to perform?
Thanks,
-W
- Creating a DIY window plug (blocks light, will presumably seal the window)
- Buying a fitted Indows window-insert (expensive, but effective?)
- Fancy soundproofing curtains from Residential Acoustics
- DIY-building an acrylic internal second window - basically a DIY Indows insert
Thanks,
-W
