Y
		yun
Hi everyone! I seem to be having a problem with my portastudio 424 mk2 erasing one of my tracks; track 2 never seems to erase properly. If I try to record over track 2, the original recording gets half erased/new recording is recorded over. My quick solution is to just turn over the track and erase it via track 3. It works but it is pretty inconvenient.
At first, I thought the erase tape head was being defective but since track 2 is not on the outside of the tape track layout, I feel that the tape head is not totally screwed up yet. This is what I've done with negligible improvements:
- Cleaned the tape heads with isopropyl alcohol
- Run a demagnetizer on the tape heads.
- Opened up the unit and checked the erase signals. I probed the erase signals and each one showed a healthy bias signal
The only thing I haven't done is try to realign the tape heads but I'm not even sure how to do that properly (can't find a service manual anywhere...). Any tips on how to fix this? I will supply more info if needed and will understand if the tape head really is screwed up! Thanks!
