Eleanor Fudd
Member
I have just acquired a combination mic preamp-compressor. Radial PreComp™ Channel Strip
I also ordered a mic preamp-EQ combo. Radial PreMax™ Channel Strip
The Pre/EQ unit has a switch to change the impedance to instrument level, but the Pre/Comp does not. Would a passive or active Direct Box take DI guitar level to the correct level for feeding the thing through the preamp without instrument level? Or, to put it in more general terms, can an instrument be fed into a mic preamp if the level is adjusted first?
Thanks for advice on this.
